Home > Maintenance & Modifications > Fitting Jate rings
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Fitting Jate rings
I'm trying to fit some Jate rings to the back of my 90 300TDi however there is a flat strip of metal that could present a problem. This is what I'm on about
Is it just a case of ignore it and it'll be fine, or is there anything else I can do?
TIA
Maverick
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #13834 4th Aug 2009 6:51pm
mse
I dont see any issues with that - ive had them fitted in similar scenarios (they soon move in use) Mike
Post #13835 4th Aug 2009 6:58pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Won't it bend the bracket under load? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #13970 7th Aug 2009 11:59pm
Grockle
Yes it will damage that part of the cross member,I'd contact the supplier. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13983 8th Aug 2009 9:20am
mse
I would disagree - it will pull up, yes, but unless your snatching around i doubt it will do much more. Mike
Post #13992 8th Aug 2009 12:43pm
Maverick
Well I fitted them to tow my series 3 out the way, and they actually split the metal, creating a cut, so to speak, that the jate rings go into. But they worked perfectly! Thumbs Up Ben
Post #14686 26th Aug 2009 11:19pm
