Home > Puma (Tdci) > Corrosion on the windscreen surround! |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
My 110 had the same problem after two years.
Took the dealer quite a long time to sort it out. Bob |
19th Dec 2011 9:57am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
Is this the drivers or passenger side and was it on a weld seem? Would be good to know if there is a common problem. A couple of spare windscreen frames is on the top of my Defender spares list to keep her going
19th Dec 2011 11:17am |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
I had this and some bulkhead corrosion on the inside of my 06 plate 110. I found the corrossion in Oct, I get my truck back from the dealers this week having had a new bulkhead and windscreen surround fitted under warranty.
Every Defender I have had has suffered the same. |
19th Dec 2011 11:20am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
common fault, ours was repaired earlier this year,Hunters use Chartwells bodyshop in Derby, they made a very good job of it. 2.4 90 XS
19th Dec 2011 11:21am |
Anyone got any pics or can detail exactly where the corrosion areas are - it would be useful for us all, especially if ultimately new bulkheads/frames are need after warranty
19th Dec 2011 11:32am |
Passenger side in two places, top patch was on the front of the frame about two inches from the roof (just below the level of the windscreen top) and the second are was about 4 inches below this on the front/side angle. No welds or seams just plain rot Bob |
19th Dec 2011 11:33am |
Thanks Bob I know when some windscreens are put in the tools they use can scrape any paint off leaving exposed bare metal (I think this was the fault with my TD5 also!)
Luckily a windscreen frame can be easily sorted but a bulkhead....that is not good, knowing which areas to keep an eye on would very useful... |
19th Dec 2011 11:35am |
Both areas of corrosion started with the paint bubbling. At the same time as I noticed the windscreen frame problem I found the same on the offside passenger door.
All sorted under warranty. Bob |
19th Dec 2011 12:04pm |
Just reminded me to get my screen out and do a proper, permanent job on the frame and seal Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
16th Apr 2012 9:11pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6074 |
When I built my 110 3 years ago, i had all the bodypanels shot blasted back to bare metal, including the screen frame.
This was then sprayed by a proper body shop (they do all the bodywork repairs to my local dealership) and this frame is now bubbling/corroding at the bottom |
17th Apr 2012 7:40am |
Red Desert Member Since: 23 Aug 2010 Location: Lake Constance Posts: 53 |
the one and only solution for this problem is: http://en.wikipedia.org/wiki/Anodizing |
23rd Apr 2012 11:14pm |
