Home > Maintenance & Modifications > Small compressors |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
This is pretty good and popular......
http://www.ebay.co.uk/itm/280544780009?ssP...1423.l2649 |
11th Apr 2012 6:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20474 |
heard of the T max range the price is very very good. I wonder where it would be best mounted (if it can) rather than just having it portable. |
11th Apr 2012 6:31pm |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
I have a T Max which I intend to mount at in the rear wheel arch, feeding 3 PCL connectors dotted around the truck.
Planning to use a pressure sensitive relay from Matt Savage and have it switched from the rear. Turn it on, system pressurizes and then when a PCL accessory is plugged in the relay triggers the pump again. It will take a little longer than a system with a tank but much simplier. 2002 Defender 110 DC |
11th Apr 2012 6:39pm |
Sounds like a plan. What about the muck dirt and water under there? |
11th Apr 2012 6:43pm |
I would box the compressor in using ally sheet, extending the breather into the rear of the pick up bed.
The piping would be simple push fit PVC tubing, PCL's placed by each rear door and the back. 2002 Defender 110 DC |
11th Apr 2012 6:49pm |
Sounds a good idea would you need some sort of venting for heat dissipation? |
11th Apr 2012 6:55pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
for filling tyres then the bog standard 20 quid job works fine. Takes a bit longer to fill up but not £100+ longer.
Pom |
11th Apr 2012 6:58pm |
The piping would be simple push fit PVC tubing, PCL's placed by each rear door and the back.[/quote]
Sounds a good idea would you need some sort of venting for heat dissipation?[/quote] If I were going to be using it for long periods then yes, but I don't envisage using it for more than a few minutes at a time. Perhaps a louvre on the back of the casing if it becomes a problem. As for the cheaper ones I totally agree - I had a £3.99 from a garage job last time we were in Morocco and it inflated my tyre back to road pressure quicker than a couple of £100 truckair compressors. Mine didn't melt like those either! 2002 Defender 110 DC |
11th Apr 2012 7:21pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
My opinion here http://www.defender2.net/forum/topic7878-30.html
get a CO2 bottle or put a airco compressor conversion if you dont have airco. just my 2 cents |
11th Apr 2012 7:33pm |
