Home > Technical > somke on start up
mega
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
somke on start up
Hi can anyone help . First thing in the morning when I start the engine I get a big ball of blue smoke, but is clear on start up the rest of the day ,2.4 puma 15,000 miles . Confused
Post #137252 5th Apr 2012 7:14pm
RobKeay
Mine does that but it's more of a cloud. Don't know what causes it, would be interested to know.
Post #137257 5th Apr 2012 7:26pm
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
Un-burnt fuel = injectors may need servicing Smile Good things come to the wild and free
Post #137273 5th Apr 2012 7:59pm
mega
Hi Musketeer, I thought leeking fuel would produce black smoke ?
Post #137290 5th Apr 2012 8:44pm
The Musketeer
It depends. Although blue smoke is often associated with oil leakage/problems when it is just on start up rather than all the time/gear changes especialy then it is normally some unburnt fuel left in the exhaust system or an injector problem.
Generally;
Blue = Fuel or Oil
Black = Oil
White = Water.
Sam
(All this comes from my old man, an agricultural engineer of 42 years that has owned, broken, fixed, built, made LRs since 1968) Good things come to the wild and free
Post #137302 5th Apr 2012 9:03pm
mega
Thanks for the info, could it be the turbo seals ?
Post #137313 5th Apr 2012 9:15pm
rossy
I believe a bit of smoke is normal. I've noticed the colder the weather the greater the volume of smoke. If its above 10 deg outside there's none. Maybe its the ECU dictating things based on temp. I have also seen this in 2 other Pumas and as mine seems to burn no oil whatsoever between changes I don't think its anything to be concerned about
Post #137321 5th Apr 2012 9:19pm
mega
Hi Rossy, the dealer said its normal but then he would Thumbs Up
Post #137327 5th Apr 2012 9:30pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Definitely seems to be temperature related. Confused LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #137339 5th Apr 2012 10:10pm
AndrewS
Are you waiting for the glow plug light to go out before you start the engine ? 130's have feeling's as well you know Smile
Post #137340 5th Apr 2012 10:17pm
The Musketeer
When the temp is lower she needs more glow plug captain! Very Happy Good things come to the wild and free
Post #137341 5th Apr 2012 10:21pm
RobKeay
Maybe on a cold day it's worth doing the glow plugs twice. When I first got mine it used to knock like a Dutch girl in a basement. An ecu update sorted that. The blue smoke seems to have got worse and apart from yesterday the weather is getting warmer. Maybe there's another update.
Post #137344 5th Apr 2012 10:45pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
The Musketeer wrote:
Blue = Fuel or Oil
Black = Oil
White = Water.
Sam, think you have that wrong, on a Diesel engine it should be
Blue = Oil
Black = Fuel
White = Water Richard
Either a 90, 110 or 130.
Discovery 5
Post #137350 5th Apr 2012 11:48pm
mega
Here's a link to a video of my defender starting from cold with the glow plugs used twice clearly showing the blue cloud of smoke.
&feature=youtu.be Big Cry
Post #137416 6th Apr 2012 10:11am
pom
normal. Mine did the same.
Pom
Post #137421 6th Apr 2012 10:39am
