Home > Td5 > Defender dashboard dial lights
excossack
The backlight for the fuel dial has packed up. So question time:
What type/rating of bulb are they ?
Has anyone changed these to LED bulbs and if so what colour works best? White(like standard) or other colours? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #136942 4th Apr 2012 7:45pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
They are 509T bulbs, weird looking things. You will need a stiff pair of tweezers to remove them. They twist-lock in place if I remember rightly.
LED ones make no difference, as the light is put through a green filter anyway. Ask me how I know Embarassed
Post #136957 4th Apr 2012 8:06pm
excossack
Cheers. I have heard I need a good pair of tweezers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #136960 4th Apr 2012 8:13pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Type in
Land Rover Defender LED lighting upgrade, into YouTube and our Aussie mate Bret shows you how it's done
Sorry am on iPad so can't get the link as it goes to the app Banging Head ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #136985 4th Apr 2012 8:39pm
excossack
Cheers, I will look at Brets video and see what he has to say on the subject. 1999 Defender TD5 110
Regards
John M0VAZ
Post #136994 4th Apr 2012 8:49pm
Retroanaconda
Actually the lighting for the fuel gauge is not a 509T bulb, these are only used in the speedometer head (two of them in there).
The lighting for the other gauges (and the heater controls) is by smaller 1.2W 'wedge' bulb. Usually referred to under a reference of 286. Available at all decent motor factors, online (VWP etc.) and even in Halfords I believe.
See here: http://www.retroanaconda.com/landrover/200...formation/
Post #137032 4th Apr 2012 9:11pm
twopoint6khz
That'll teach me not to read the thread title properly Embarassed
However I remember watching that Aussie video, and IIRC he is doing it to a much older vehicle in which the dials are lit differently. Therefore it doesn't really work on later vehicles.
Post #137043 4th Apr 2012 9:43pm
Retroanaconda
Yes, Td5 dials are already fantastically illuminated and any addition of LED lighting is rather pointless as pointed out above.
This the reason so many people (myself included) fit the Td5 instrument cluster to earlier vehicles.
Post #137047 4th Apr 2012 10:08pm
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Just out of interest does anyone know how to change the speedo bulbs on a TD5 ? as have one that's gone. I have a spare instrument cluster knocking about and is completely different to the earlier type. Is there a tool or something to reach down onto the back of the bulb ?
Post #137521 6th Apr 2012 7:50pm
Retroanaconda
See the link in my first post above, there's some photos of the process on there.
Basically you want a pair of tweezers for the job, very easy otherwise.
Post #137529 6th Apr 2012 8:22pm
Peter
Okay, yes, sorry did not see link, however:
I actually found a much easier way to do it. Using my £10 Halfords socket set. I found the 11/32" socket on the screwdriver attachment works well, and is much quicker and less fiddly, holds it perfectly. Very quick and easy to replace it again too.
Post #137745 7th Apr 2012 11:02pm
Herdwick
Found it easier still,
Just took the speedo to the dealer, asked for new bulbs, they removed the old ones and fitted new ones whilst I waited.(About 1 minute with their long nosed pliers).
Post #138078 9th Apr 2012 2:19pm
excossack
Eventually got around to sorting this and went for a T5-286 LED bulb. Early thoughts, I think the LED bulb is much better than before, so I also changed the temp gauge bulb as well.. Just the clock and the speedo ones to change 1999 Defender TD5 110
Regards
John M0VAZ
Post #145223 15th May 2012 9:50pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
handy to know they fit ok.
My temp gauge light has a habbit of not working every time, so I was going to replace them all with brighter versions while I'm in there anyway
Post #148830 6th Jun 2012 3:45am
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Both bulbs available at the frauds but its just cost me £1.98 for one much cheaper on the bay if you have got the time Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #213559 23rd Feb 2013 12:12pm
