![]() | Home > Td5 > Is it possible to have an oil leak free TD5 ? |
Just check the tightness of the oil filter, I had one that wouldn't stay done up and every couple of months or so would loosen off just enough to seep oil past
marsie Member Since: 17 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
Had a customer say to me recently
"the transfer box leaked from the day i got it and only stopped leaking a week before it blew up" ![]() ![]() Paul ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5900 ![]() ![]() ![]() |
T/C seal has been changed by a garage this time and so far its OK, Oil filter is tight. 1999 Defender TD5 110
Checked breather and all is clear.
Cleaned up the cam seal on the front of the engine and sealed with the same stuff they use on Puma sumps. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I think I have found the source of another leak, the oil pipe thats on the underside of the turbo. I found some oil at the flange joint with the turbo. Order new seal for that. 1999 Defender TD5 110
Today replaced the turbo oil return feed pipe gasket. When I say replace, there wants a gasket there in the first place. Fingers crossed thats another leak fixed.
Next I think is the oil filter housing gasket, which I think is leaking and dripping down behind the engine mount 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
I think I've sorted mine today. I replaced the rocker cover gasket it looked like its been leaking at the back of the engine for a while.
I replaced that one last year and i think its starting to weep slightly on the corner above the FPR 1999 Defender TD5 110
Turbo oil return pipe leak fixed. I have just ordered rocker seal and front cam seal. 1999 Defender TD5 110
Front cam seal and rocker gasket replaced.Rocker bolts tightened to 10nm.
Lets see how long they last this time 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
