Home > Technical > Instrument binnacle back lighting gone! |
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 |
As per the subject! Any ideas? It's not a fuse as farad I can see.
2nd Apr 2012 8:04am |
probably a loose wire because the puma dashboards are all lit with LEDs
2nd Apr 2012 10:57am |
Aye, just the 3 clocks illumination.
2nd Apr 2012 11:54am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20477 |
All of them? I thought it was just the 2.2's that had LED? |
2nd Apr 2012 11:56am |
mine's a 2010 2.4 I replaced the dashboard when I imported it, when replacing the KPH to MPH decal, all LEDs were visible on the circuit board. Not sure about the central switch console - filaments or LEDs. It's the same unit on FL2 also, so it's probably been around since FL2 |
2nd Apr 2012 12:01pm |
Just checked, it's the three round displays and the headlight and side light warning lamp.
2nd Apr 2012 12:24pm |
Fixed, my son spotted a side light out, same at back, turned out it was a fuse and it's some how linked to the instrument back lighting! Smart move Land Rover!
3rd Apr 2012 6:46pm |
wow - that's worth remembering ... thanks for the update
3rd Apr 2012 7:26pm |
A weird one for sure!
4th Apr 2012 8:18pm |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 |
I Have found that the wire is very thin and have had a few in with internal brakes in the wire , so when you move the wire the lights come on a pain to find , untill i have a few in , also on the Puma heater control,s had the same problems ,
4th Apr 2012 8:43pm |
