Home > Puma (Tdci) > Door seal on window glass
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Just curious... On the Australia Puma's the interior door plastic panel sits about 1/8"-1/4" proud of the window glass but on the out side the glass has the rubber strip pressed against it. On my old Tdi there is an inner plastic strip that touches the glass.
Is this the same in the UK and if so do you notice a rather cold breeze coming up through the door?
Of course the obvious question is: "How do I fix this draft?" 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #13514 28th Jul 2009 12:11pm
Grockle
Hi Derek,there isn't an inner rubber strip on the Puma, if you have a draft check the alcathene sheet for rips etc.behind the door card,how's that awesome trip going ?. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13516 28th Jul 2009 1:01pm
spudfan
Ireland
Just checked, the outside rubber is tight to the glass. There is a gap between the top of the inside door trim and the window. There is no plastic add on lip as in the tdi. I have no draughts. This could be caused by an ill fitting door seal or a door that is not lined up 100%. You are probably no further forward now but at least you know that your vehicle is pretty standard. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #13517 28th Jul 2009 1:07pm
dm_td5
Thanks probably is down to alignment then. I've never had the panel off so the sheet should be intact still. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #13553 28th Jul 2009 8:31pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
aye. same One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #13560 28th Jul 2009 10:10pm
Bosun
I need to take one of my door cards off, any tips?
Thanks,
Post #13639 31st Jul 2009 7:55am
spudfan
Ireland
The only weak point in this is the fitting for top left hand corner of the trim as you hold it in your hand, face out after removal. If you break any of the other plastic fittings they are easily replaced. The top hand left corner is different. but if it breaks -which I am 99.9% sure that it will. do not despair. It can be screwed back on to the inside of the trim using small screws. The trim is very thick just here so it will hold the screws. This is not explained very well but you will understand once the trim is off.
The fitting here is all one unit whereas the rest are individual plastic screw types which just slot in to a holding piece.Someone else might be able to explain it better. Mine came off but the top left fitting broke off but was successfully refitted with very small screws. 1982 88" 2.25 diesel
Post #13653 31st Jul 2009 11:34am
Grockle
Spot on Spud,they are a swine to get off undamaged,thanks for the tips Thumbs Up 2.4 90 XS
Post #13655 31st Jul 2009 12:09pm
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
Rather than just pulling the door card off at the clips use a flat screw driver to pull the clips out , there is a groove in the clip where the screw driver will fit if you push it in between the door nd the card, if you know what I mean.
You may be doing this already but it is just something that I have learnt the hard way, pulling the card off works but there is a good chance that the clips break off in the door or even worse break of the card.
My 2 c.
Post #13682 1st Aug 2009 8:30am
Grockle
Fontuin, you can get a proper tool, it looks like a small open ended spanner made of tough plastic so it doesn't damge the clip or panel Thumbs Up 2.4 90 XS
Post #13683 1st Aug 2009 9:40am
AndrewS
Post #13687 1st Aug 2009 11:02am
