Home > Puma (Tdci) > fault code
nivmargalit
Israel 2007 Defender 110 Puma 2.4 SW Stornoway Grey
fault code
Hi
I have been conect to a fault reader and find out the following codes:
p0404
p0100
p1103
p0299
p0234
p1402
What are the faults - explanation.
Thanks
Niv
Post #135410 29th Mar 2012 10:55am
Naks
Re: fault code
Use BAS' website: http://bellautoservices.co.uk/ --
Post #135412 29th Mar 2012 11:09am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
P0404 Exhaust Gas Recirculation “A” control circuit range/performance
P0100 Mass or Volume Air Flow A circuit
P1103 Mass Air Flow Sensor in Range but higher than Expected
P0299 Turbocharger/supercharger A underboost condition.
P0234 Turbocharger/supercharger A overboost condition
P1402 Exhaust Gas recirculation metering Orifice Restricted Shocked
Post #135415 29th Mar 2012 11:16am
Naks
sound like you need a new EGR Wink --
Post #135417 29th Mar 2012 11:18am
nivmargalit
Thanks you all.
First I will try with clening the EGR, if it whont help I will change it.
I found this site :
http://www.permoveo.ltd.uk/tabid/123/Diagn...fault.aspx
Post #135432 29th Mar 2012 12:51pm
Lorryman100
Does the fault code reader differentiate between tested and untested dtc's? If there is no obvious degradation in engine/fuel performance, or any strange sounds emanating from the EGR on shut down, I would say the codes you have listed are normal untested dtc's which will clear themselves after 40 ignition cycles, unless they reoccur within the 40 ignition cycles, but as they are untested this is not an issue. I would only be concerned if the MIL was illuminated or the fuel use had increased significantly. Some DTC's taken from my Puma over the last 2 years:
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file
0404 - 72
Exhaust gas recirculation (EGR) control circuit
range/performance
0404 - 73
range/performance
actuator stuck closed
0299 - 00
Turbocharger A under boost condition
0100 - 29
Mass or volume air flow A circuit
signal invalid
1103 - 00
Mass air flow (MAF) sensor in range but
higher than expected
1402 - 17
valve metering orifice restricted
circuit voltage above threshold
0234 - 00
Turbocharger A over boost condition
As you can see above I have had at some point or other the same codes you have listed and my Puma still runs like a little sweetie with them. Thumbs Up
Below is an explanation of DTC's I did in another post:
Lorryman100 wrote:
Thought I would try and explain the differences in DTC codes. So here goes:
There are basically two types of DTC codes for OBDII Diagnostics:
Emissions related DTC's Tested DTC's
Type A
1. Emissions related.
2. The Malfunction Indicator Lamp (MIL) will be illuminated as soon as the error occurs.
3. Stores a freeze frame DTC after one failed driving cycle.( history DTC is stored )
Type B
2. Sets a Pending Trouble Code after one failed driving cycle.
3. Clears a Pending Trouble Code after one successful driving cycle.
4. Turns on the MIL after two/three consecutive failed driving cycles.
5. Stores a Pending Trouble Code as a DTC after two consecutive failed driving cycles.
Conditions for Clearing the MIL/DTC – Type A or Type B
The MIL will turn off after four consecutive driving cycles in which the diagnostic runs without a fault.
A history DTC will clear after 40 consecutive warm up cycles without a fault.
DTC(s) can be cleared by using a scan/diagnostic tool.
Non–Emissions Related DTCs Un Tested DTC's
Action Taken When the DTC Sets
1. The Malfunction Indicator Lamp (MIL) will not illuminate.
2. The ECM will record a DTC at the time the diagnostic fails.
Conditions for Clearing the DTC
How to read a DTC Code
The DTC value will help you narrow down the specific component or module in question. A DTC has a standardized format that can be interpreted as follows:
The first part of the DTC is the Alpha Designator. The alpha designator will be:
B - Body electronics (i.e., door and hood latches)
C - Chassis (i.e., traction control or ABS)
P - Powertrain (i.e., engine, transmission)
U - Network communications for the different control modules
Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code.
0 = Generic (The diagnostic codes that are required by law on all OBD II systems are "generic" in the sense that all vehicle manufacturers use the same common code list and the same 16-pin diagnostic connector. Thus, a P0301 misfire code on a Ford means the same thing on a Vauxhall, Citroen, Toyota or Mercedes.)
1 = Enhanced ( Each vehicle manufacturers also have the freedom to add their own "enhanced" codes to provide even more detailed information about various faults. Enhanced codes also cover non-emission related failures that occur outside the engine control system. These include ABS codes, HVAC codes, airbag codes and other body and electrical codes.)
Third Digit - Sub-System
The third digit denotes the type of sub-system that pertains to the code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Fourth and Fifth Digits
These digits, along with the others, are variable, and relate to a particular problem code error number
So let's diagnose a DTC, I've picked P0404-73 EGR control circuit range/performance: actuator stuck closed
so we have:
P = Powertrain (engine, transmission)
0 = Generic
4 = Emissions control
0 4 =This is the specific error code within Emission control. In this case the EGR control circuit range/performance
-73= This is a specific problem, in this case the actuator is stuck closed. 72 means its stuck open.
HTH Brian.
Post #135449 29th Mar 2012 2:35pm
nivmargalit
Thanks Brian,
I do not have any change of fuel or strange noise
Post #135866 31st Mar 2012 12:13pm
