Home > Technical > Adjustable tow hitch height
mowcop
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Hi,
I have the normal factory tow hitch
But the hitch is too high for my tri-axle trailer (front wheels keep locking up) has any one got one of these fitted?-
Would anyone be willing to measure from the floor to the top of the 52mm ball?
Thanks,
Martin.
Post #13385 25th Jul 2009 12:16pm
Grockle
Welcome, Is your ball on the lowest mounting holes ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13386 25th Jul 2009 1:18pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Hi mowcop
Mine is 50cm at it's lowest mounting holes but it's a 130. I don't know if my rear crossmember is higher than a 110 or a 90. 130 crew cab
98 V8 Disco
Post #13393 25th Jul 2009 2:42pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi Mowcap,
Mine is standard factory fit with towball at lowest position. 525mm to top of towball.
Post #13398 25th Jul 2009 5:48pm
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
90XS unladen using the Dixon Bate adjustable tow hitch, as per your picture, the lowest height from ground to the top of the tow ball is 420mm. Get the tow hitch from paddocks or similar, not from the main dealer, who charge over £200 more for the same thing!
Post #13402 25th Jul 2009 6:22pm
mowcop
Hi,
My 110 on 750xR16 has measured in at 55cm to the top of the ball, as shown~
My 127 Rapier has this superb adjustable job on a home made mount and runs at 36cm (no skidding)
Looks like I need to invest in the height adjustabe type, but I need to ensure that it will be lower than it is at the moment.
Post #13403 25th Jul 2009 7:10pm
Laurie
My Dixon-Bate was £135 from my main dealer (Caffyns)
Post #13515 28th Jul 2009 12:56pm
Grockle
mow,someone keeps putting an old boot behind your trucks. 2.4 90 XS
Post #13518 28th Jul 2009 1:24pm
110SEB
The Dixon Bate on ours, on the lowest setting is perfect for an old low level trailer we have. It doesn't raise the front of the trailer at all. That's with a plate with a 52mm ball attached on the lowest hole of the slider.
We also have another plate with a NATO jaw on. Plugged into the highest hole on the slider, it pulls the Sankey like a dream at the perfect height.
Dixon Bates are the best IMHO. It won't smash your shins in either, when rummaging in the back, if you take the slider plates off between tows.
Post #13519 28th Jul 2009 2:25pm
110SEB
Post #13520 28th Jul 2009 2:25pm
110SEB
Post #13521 28th Jul 2009 2:25pm
110SEB
Post #13522 28th Jul 2009 2:25pm
110SEB
Thumbs Up
Post #13523 28th Jul 2009 2:26pm
110SEB
Thumbs Up
Post #13524 28th Jul 2009 2:26pm
Grockle
SEB, we are taking notice honestly. 2.4 90 XS
Post #13525 28th Jul 2009 2:28pm
