![]() | Home > Td5 > handbrake adjustment |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Jack up one rear wheel (After chocking the front ones)
release handbrake Crawl underneath with a 17mm socket. adjust the nut on the back of the handbrake drum, one notch at a time, until the drum/rear prop won't turn, slacken off one or 2 notches. get back up into the cab, pull the handbrake on and see if it feels "right" (should be 3 or 4 clicks from off to fully on) |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
![]() ![]() ![]() Def 90td5 CSW xs 2006 |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Can you adjust the position of the handbrake light switch? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy ![]() |
Not easily.... the holes for the fixing screws for the switch are drilled into the mounting plate for the handle, so you'd have re-drill, or you could bend the little arm that presses the switch. looks a bit flimsy though, so be careful!
Cheers DJ, its just that my lever has to be totally home for the light to go out 2005 TD5 90 Hard Top
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Exactly the same on my 300tdi ![]() |
and my MY11 Puma
![]() But shout it at them in German because life is also terrifying and confusing... |
I shalln't lose any sleep over that particular issue then
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
While you're at it, put some insulation on the wire. It rubs on the mounting and will eventually rub through.
Merlin |
a-just adjusted mine (pardon the pun). Took less than 10 minutes and I was shocked how far out it was
![]() Even though mine's a Puma with a cable-actuator, I followed an older Haynes handbook - tighten the adjusting nut until the jacked wheel won't move (conveniently kickable from underneath) then back off the nut 1 and 1/2 turns. Now it takes 3 handbrake notches from full-off to full-on ![]() Bloody German dealers said 5-7 notches and near-vertical lever is "standard" - bloody idiots ![]() Still have to see if the clattering goes though - I will report back... p.s. I honestly believe 6 months membership of this forum should be compulsory before buying a Defender ![]() But shout it at them in German because life is also terrifying and confusing... |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
what a great idea. ![]() |
