Home > Td5 > Jittery ride
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Jittery ride
My 2005 TD5 90 is a bit jittery at speeds above 50. I.e. the steering wheel shakes slightly. And the ride is choppy and can feel all the bumps in the roads.
Have just put a new steering damper on and this has made a slight improvement.
Would this be down to shocks or springs or both and or bushes ?
Its shod with BFG A/T's on Wolf rims.
Advice welcome, from others who have a more pleasant on road ride.
Post #134316 25th Mar 2012 6:38pm
Simple question but have you had your wheels and tyre's balanced and aligned when fitted?
Post #134318 25th Mar 2012 6:41pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
also simple question - check all wheel nuts are tight - once had some left loose by a kind mechanic - Shocked BM52
Post #134337 25th Mar 2012 7:49pm
landy andy
Swivel peloads, and pan rod bushes.
Andy
Post #134345 25th Mar 2012 7:57pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
The above, plus the drop arm joint. These go wobbly quite frequently.
Post #134348 25th Mar 2012 8:02pm
Peter
Wheels balanced, even tried backs on front. Wheel nuts are tight.
Post #134403 25th Mar 2012 10:11pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Have you previously owned a 90, how does this one compare, if not try a ride in a friends see if they are the same. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #134436 26th Mar 2012 8:04am
Peter
My other 90 is seriously modifed 3" lift rear with 11" drop out OME with Gwyn Lewis add ons and OME front 2" lift, orange polybushed RR 300TDI Auto pump turn up full, with 8274 up front D44 bumper and skid plate, with spare on bonnet, so yes its a tad different.
I reckon its the OMG standard shocks.
Post #134895 27th Mar 2012 8:53pm
Peter
Took truck down to a mate's garage, and checked out the obvious - shocks springs bushes steering etc . One thing he did notice was the slightly rounded wear of the front tyres. From memory this can be caused by mis inflation of the pressures. Swapped for rears, although the suspension is still as crashy as ever, the vibration through the steering wheel has diminished significantly over 50 mph, and can now get up to 80 no problems.
Post #139306 14th Apr 2012 10:41pm
