Home > Td5 > Jittery ride |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20347 |
Simple question but have you had your wheels and tyre's balanced and aligned when fitted?
25th Mar 2012 6:41pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
also simple question - check all wheel nuts are tight - once had some left loose by a kind mechanic - BM52
25th Mar 2012 7:49pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
Swivel peloads, and pan rod bushes.
Andy |
25th Mar 2012 7:57pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
The above, plus the drop arm joint. These go wobbly quite frequently.
25th Mar 2012 8:02pm |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 |
Wheels balanced, even tried backs on front. Wheel nuts are tight.
25th Mar 2012 10:11pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Have you previously owned a 90, how does this one compare, if not try a ride in a friends see if they are the same. Original Member Pie n Pea Club.
110 HCPU Tipper |
26th Mar 2012 8:04am |
My other 90 is seriously modifed 3" lift rear with 11" drop out OME with Gwyn Lewis add ons and OME front 2" lift, orange polybushed RR 300TDI Auto pump turn up full, with 8274 up front D44 bumper and skid plate, with spare on bonnet, so yes its a tad different.
I reckon its the OMG standard shocks. |
27th Mar 2012 8:53pm |
Took truck down to a mate's garage, and checked out the obvious - shocks springs bushes steering etc . One thing he did notice was the slightly rounded wear of the front tyres. From memory this can be caused by mis inflation of the pressures. Swapped for rears, although the suspension is still as crashy as ever, the vibration through the steering wheel has diminished significantly over 50 mph, and can now get up to 80 no problems.
14th Apr 2012 10:41pm |
