Home > Technical > defender 200tdi overheating,
Amar
Hi, my 90 200tdi been overheating intermittanly, When driving for about 10-15min from cold it goes above half way mark on the gauge, as soonas i give it a throttle say when on mway it rises to the red! but with no visible signs of overheating.
i removed the rad and found it was pretty much goosed, so changed it and the thermostat, refilled coolant and still the same. no pressure loss from engine, no oil or watermix so gasket should be good. Any help would be appreciated
cheers Amar Amar Smile
Post #13397 25th Jul 2009 6:08pm
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
You could try removing the thermostat. It will eliminate a thermostat problem (new ones can be faulty).
I guess you dunked the old one in boiling water to see if it opened or not?
Is it the same as the 300, which has a viscus fan? Does the fan cut in and run ok?
Be careful when mucking about with the cooling system when it is hot. If you break a pipe or take the coolant cap off, the coolant will vaporise & cause very nasty scalds.
Just a few ideas. Hopefuly it will not be the head gasket.
Post #13399 25th Jul 2009 6:49pm
mse
200 and 300 are very cool running engines normally.
I assume the water pump is working? Thermostats do fail as mentioned Mike
Post #13404 25th Jul 2009 9:57pm
mowcop
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
check and double check all the earth straps to the engine, chassis and box.
Post #13415 26th Jul 2009 7:45am
spudfan
Ireland
Mine is the opposite, it barely gets into the white! Running even cooler now that I have changed the radiator. Thermostat is next on the agenda.Went down on the emissions test recently. The mechanic said she was 500 revs short of the required maximum revs so he could not test her. Doing checks afterwards I found that the adjustment screw on the pedal was preventing it travelling down to it's maximum. I have adjusted it back to give full movment now. The butterfly on the injector pump was not reaching the stop screw. It is now. Just thought I would mention it to you. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #13417 26th Jul 2009 9:20am
Amar
i changed tested the temp sender unit and that was ok, water pump sounds healthy and no leaks, just wondering how the earth straps to engine chassis or gbox could make a diff? just that i had a clutch installed shortly before this problem occured...wondering if the earth to the gbox could be at fault? any ideas Confused Amar Smile
Post #13630 30th Jul 2009 10:30pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
My 200tdi had a similar 'problem', when the cooling electic fan was turned on (mines manually switched) the guage rose quite a bit. well into the red. Earth strap was renewed and problem solved, I'm thinking that if you have an electric fan that turns on automatically (say when on a motorway) at a preset temp then the same might happen.
I had previously changed the sender and guage for a vdo but didn't help. Now sits nicely at 80 all the time and i never switch on the fan.
Hope you have a similar simple fix.
DJ
Post #13633 30th Jul 2009 11:11pm
mowcop
Hi,
I the earth strap is not connected in the right place and with a good contact, other electrical items can earth through the temp sender, think about it the engine and gear box are on rubber mounts so one of the easyest paths is through the sender circuit.
Post #13662 31st Jul 2009 3:09pm
niglyn
Sounds like it could be an earth problem as the clutch was changed just before the problems started. Many cars have the earth strap located on one of the bolts holding the bell housing to the engine. Have a crawl underneath & see if you can see the strap, it may just be dangling & the clutch monkeys forgot to re-connect it. (I forgot it once & the choke cable became the earth & got red hot Embarassed )
You could run in a couple of temporary earth straps from any convienient bolt on the engine to thew chassis. Also worth checking the battery lead which runs to the outrigger below is ok.
Post #13668 31st Jul 2009 6:27pm
Amar
thanks guys, will have it on the ramps on sunday and check out the earth straps first! keep you posted Smile Amar Smile
Post #13673 31st Jul 2009 8:46pm
