![]() | Home > Maintenance & Modifications > Best of the NAS Lamps? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6146 ![]() ![]() ![]() |
I bought the ones for my 110 from Bearmach. they're the perei jobbies (filament bulbs though, not LED).
Can't remember the price, but not too bad at all really. Had to elongate the main hole in the bodywork with the die grinder a bit, but nothing too bad. They've been on for 3 years now, no problems or water leaking into them at all. |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
My advice would be to make sure they are Perei who make the genuine ones. I've used Dun Bri. Mobile Center sell LED ones and might be able to help.
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
yep Tim @ www.mobilecentre.co.uk Putting Dreams on Drives at JLR Solihull..
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
Also try your local commercial vehicle motor factor - LEDs are becoming very common for trucks and busses. I got my lamps for not a lot of money and they have been very good so far. IIRC they are Durite items - If I remember I will check the lamps tomorrow in daylight.
All you need to do is get the easyfit plinths from BoB. |
I'm part way through fitting NAS lights to mine. I've used BoB plinths on the front as it's so much easier and I like the slightly bug-eyed look:
![]() Click image to enlarge I'll do the back with standard plinths (if I ever get time to do it ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
if its a TD5 you should'nt have to cut bigger holes at the back... Putting Dreams on Drives at JLR Solihull..
Ooh, really? That'll be a nice surprise
Spurred on by the idea that it wouldn't be as involved as I first thought, I fitted my rear NAS lights today
![]() ![]() Click image to enlarge Thanks for the pointer, Adafish ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Fitted these to my old 110 Hi-cap
![]() I used BOB plinths on the front to save cutting holes. Avoid all other lamps other than Perei as they let water in.. ![]() Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
No need to fit NAS lamps to be seen - our 70mm LED kit will outperform the standard lamps and fit straight on without bodywork mods or plinths.
PM SENT 993 Varioram - Guards Red
Yeah, but they don't look as good ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
What's wrong with these then? ![]() Click image to enlarge |
I'm astounded at how many of you guys have the LED headlights !
Was there a group buy with a big discount I missed out on ? |
