![]() | Home > Puma (Tdci) > First Service Warranty Work |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
Rusty window catches on the sliding windows.
Door seals coming away and getting trapped in the doors (I've had mine done twice now) heated rear screen top element failure (unless it's got the modified version) Rusty headlamp surrounds I'm sure there are more, these are just a few of my warranty items, but as it's out of warranty tomorrow it will never go wrong again ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Rear mudflap bracket fixing point splitting the rear panel on 110's especially with motorway miles!
Front and rear heated screens! Check wipers are all good, Heat coming out both sides OK, Check windows don't rattle in front doors, leaks from swivels, diff, transfer box etc, Cracked steering bush on bulkhead top, (ZeDefender has better specifics on this! He won't mind 3000 pm's ![]() Can't think of any more without pulling things apart to check, melting light contact points for instance ![]() ![]() |
Dean - keen to hear how you get on...
I've often considered "marking" a couple of items to see if the dealer actually changes/adjusts them... I'm sure my old main dealer didn't grease the prop shaft correctly - maybe worth having a look to make sure there's fresh grease around the nipples? Good luck! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
