![]() | Home > Technical > Poor radio reception |
Only using that one for FM (I have another for CB) - middle band for FM stations I want around Munich is 100MHz
![]() But shout it at them in German because life is also terrifying and confusing... |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Ok. I understand. That makes sense now.
Pete |
Nope - 3/4 wavelength for FM 100MHz is about 225cm. Because CB frequency is lower around 27 MHz (roughly 1/3 of 100 MHz) a 1/4 wave CB aerial is only slightly longer than a 3/4 wave FM one (higher frequency = shorter wavelength = shorter aerial) Brilliant for a corking FM 3/4 wave aerial as you only have to cut a bit off a 1/4 wave CB whip ![]() But shout it at them in German because life is also terrifying and confusing... |
mymini007 Member Since: 10 Nov 2011 Location: Chippenham Posts: 273 ![]() ![]() |
I am beginning to think its not a reception issue today, as i popped a cd in (old school I know)
![]() But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20634 ![]() ![]() |
Don't be to hasty some times things seem a bigger problem than they are. Check that there are firm connections to the rear of the radio and behind all speakers. Also check for any nicks or cable damage while your at it. ![]() |
I have just had the whole lot re-wired, so the connections should be spot on, will check the speakers, but to be honest the headunit is about 15 years old and has been knocking about my garage for a good portion of that time. You cant polish a turd! But you can roll it in glitter ![]() 2006 Mercedes Benz CDI320 2001 Volkswagon Caddy Van 1.9 SDi 1993 Nissan Patrol 4.2 TD 1986 90 200tdi - SOLD 1990 Mini mayfair (highly modified) - FOR SALE |
Ah that maybe why then. Worth checking the speaker connections though. ![]() |
