Home > Technical > Poor radio reception
Page 2 of 2 <12
ZeDefender
Only using that one for FM (I have another for CB) - middle band for FM stations I want around Munich is 100MHz Thumbs Up Tell someone you love them today because life is short.
Post #131585 15th Mar 2012 3:01pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Ok. I understand. That makes sense now.
Pete
Post #132251 18th Mar 2012 8:55am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
He probably means 1/4th wavelength Wink.
With a 3/4 wavelength his Defender would fall over on the first corner Mr. Green Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #132302 18th Mar 2012 1:55pm
ZeDefender
Nope - 3/4 wavelength for FM 100MHz is about 225cm. Because CB frequency is lower around 27 MHz (roughly 1/3 of 100 MHz) a 1/4 wave CB aerial is only slightly longer than a 3/4 wave FM one (higher frequency = shorter wavelength = shorter aerial)
Brilliant for a corking FM 3/4 wave aerial as you only have to cut a bit off a 1/4 wave CB whip Thumbs Up Tell someone you love them today because life is short.
Post #132353 18th Mar 2012 5:49pm
mymini007
1986 Defender 90 200 Tdi HT Java Black
I am beginning to think its not a reception issue today, as i popped a cd in (old school I know) Laughing on the way to work and it sounded just as bad as the radio, Crackly and very little volume. So I am now thinking the headunit and speakers are shot! You cant polish a turd!
But you can roll it in glitter Smile
2006 Mercedes Benz CDI320
2001 Volkswagon Caddy Van 1.9 SDi
1993 Nissan Patrol 4.2 TD
1986 90 200tdi - SOLD
1990 Mini mayfair (highly modified) - FOR SALE
Post #132491 19th Mar 2012 10:32am
Don't be to hasty some times things seem a bigger problem than they are. Check that there are firm connections to the rear of the radio and behind all speakers. Also check for any nicks or cable damage while your at it. Thumbs Up
Post #132494 19th Mar 2012 10:43am
mymini007
I have just had the whole lot re-wired, so the connections should be spot on, will check the speakers, but to be honest the headunit is about 15 years old and has been knocking about my garage for a good portion of that time. You cant polish a turd!
Post #132496 19th Mar 2012 10:49am
Ah that maybe why then. Worth checking the speaker connections though. Thumbs Up
Post #132515 19th Mar 2012 12:16pm
Page 2 of 2 <12
