Home > Puma (Tdci) > EGR Valves |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6276 |
I know its not really the answer especially when under warranty but couldn't simply go and buy a ford one or are they different?
I don't know what they cost but if relatively cheap it might be worth it? Don't get me wrong the principle of doing this when a warranty should resolve it p!sses me off but technically would this be the answer? |
22nd Jul 2009 8:19am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
LROV90,you could get in touch with Pete at BAS (www.bellautoservices.co.uk) 2.4 90 XS
22nd Jul 2009 10:21am |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
Ive blanked my EGR off and the only time I get any black smoke is when I floor it in 6th from around 50ish. I prevented the MIL light coming on by drilling a 10mm hole in the middle of the blanking plate. This reduces the higher intake pressure enough to prevent the light from coming on, with also the added affect of not recircing all the exhaust gas. NOTE: I've also had a BAS remap! |
22nd Jul 2009 12:35pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
I have a 19mmŲ hole in my blank plate and all is fine also got a BAS re-map.
22nd Jul 2009 2:18pm |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 |
Guys
to jump in and ask a dumb question, i assume from the comments above, that the EGR can be taken out, and a blank plate put in it's place, with a small hole in the midle? if so, who does the plates? and what if any difference if made? i have a JE Eng Remap -180BHP (calaimed) 450n/m torque (claimed) it goes linke stink and pulss heavy things well. Cheers keith puer claudius |
22nd Jul 2009 2:46pm |
LROV90 Member Since: 22 Jul 2009 Location: geelong Posts: 10 |
I will give the blanking plate with a hole drilled in it another go then! I only tried the plate without the hole.
Do you guys with the BAS remap get any hesitation through 2300 - 2500rpm when you put your foot down accelerating through the gears? |
22nd Jul 2009 10:58pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2025 |
I have the Bas remap aswell and get this hesitation. Pete told me it was probably the EGR valve that was the problem. I had the same fault codes as you. Pete did me a smoother remap but the hesitation was still there but not quiet so bad. The told me to EGR valve was made of plastic so they don't last long!
Daz110 |
23rd Jul 2009 9:26am |
The blanked (partially) plate will not give you any more grunt but it will make things run smoother with less smoke, when your EGR valve packs in and it will. |
23rd Jul 2009 6:30pm |
mrwoowill
make it make any difference to the economy? getting 27/28mpg at te moment. Cheers keith puer claudius |
24th Jul 2009 10:38am |
