Home > Technical > Problem with burned CDs
Axel
Germany 2012 Defender 90 Puma 2.2 SW Keswick Green
Car stereo refuses to play any burned CDs .... neither audio nor MP3 .... Sad
The CDs in question work perfectly at home and in all our other car stereos and mobile devices ... Question
Is this normal with the standard CD-player? Best Regards,
Axel
Post #131844 16th Mar 2012 1:44pm
Re: Problem with burned CDs
What type of disc are you using and brand?
Post #131874 16th Mar 2012 4:11pm
Laurie
Are you trying straight copies of CDs?
If not, are the files of the same type?
Post #131876 16th Mar 2012 4:20pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
All mine work great Mr. Green
And only use cheep Asda ones NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #131892 16th Mar 2012 5:33pm
check that you have "completed" the disc
un-completed CDs work ok on computers but will not on cd players.
Post #131893 16th Mar 2012 5:38pm
excossack
Try burning the CD at the slowest speed setting, or change the make of CDs. I have found certain cds/and also colours work better than others. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #131928 16th Mar 2012 7:25pm
Axel
Hello,
I have tried several brands so far .... TDK, Verbatim, LifeTec ... all CD-R .... and I selected "AUDIO-CD" when burning .. When I look at the files on the CD the tracks are all in format *.cda .... and - as I said - all these CDs play perfectly on my stereo at home and in the car stereos of our other cars ...
Just the LR stereo apparently can't read them .... There is NO problem, however, with ordinary/purchased CDs ... These play just fine ....
I guess, I will have to do some more testing .... I shall try to reduce the speed of the burnig process .... Best Regards,
Axel
Post #131933 16th Mar 2012 7:54pm
What computer programme are you using to write discs? And also format must be MP3
Post #131945 16th Mar 2012 8:49pm
Axel
Using a software called "Nero" ...... Best Regards,
Axel
Post #131968 16th Mar 2012 9:39pm
Laurie
As BPman says 'Have you finalized the disk?'
Post #131971 16th Mar 2012 9:59pm
I would use windows media player. Thumbs Up Even if you don't have windows system
Post #131972 16th Mar 2012 10:00pm
Axel
Yes .... "Finalise Disk" is set to "yes" .... Best Regards,
Axel
Post #132031 17th Mar 2012 11:09am
WarPig
Axel, I cant help Im afraid, but on a more interesting note my home town of Sheffield is/was twinned with Bochum. The road around the corner from me is even called Bochum Parkway. I imagine your town of Bochum must have been so excited to be twinned with a Scheiße Loch like Sheffield!
Post #132051 17th Mar 2012 1:44pm
Axel
Laughing Well .... come on ... Sheffield isn't that bad after all ... Wink
http://www.bochum.de/C125708500379A31/vwCo...Q185BOLDEN
.... right next to the beautiful Peak District .... Best Regards,
Axel
Post #132065 17th Mar 2012 2:33pm
