![]() | Home > Technical > Problem with burned CDs |
Axel Member Since: 22 Jun 2011 Location: Bochum Posts: 107 ![]() ![]() ![]() |
Car stereo refuses to play any burned CDs .... neither audio nor MP3 ....
![]() The CDs in question work perfectly at home and in all our other car stereos and mobile devices ... ![]() Is this normal with the standard CD-player? Best Regards, Axel |
Are you trying straight copies of CDs?
If not, are the files of the same type? ![]() |
All mine work great
![]() And only use cheep Asda ones NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
check that you have "completed" the disc
un-completed CDs work ok on computers but will not on cd players. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
Try burning the CD at the slowest speed setting, or change the make of CDs. I have found certain cds/and also colours work better than others. 1999 Defender TD5 110
Hello,
I have tried several brands so far .... TDK, Verbatim, LifeTec ... all CD-R .... and I selected "AUDIO-CD" when burning .. When I look at the files on the CD the tracks are all in format *.cda .... and - as I said - all these CDs play perfectly on my stereo at home and in the car stereos of our other cars ... Just the LR stereo apparently can't read them .... There is NO problem, however, with ordinary/purchased CDs ... These play just fine .... I guess, I will have to do some more testing .... I shall try to reduce the speed of the burnig process .... Best Regards, Axel |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20634 ![]() ![]() |
What computer programme are you using to write discs? And also format must be MP3
Using a software called "Nero" ...... Best Regards,
Axel |
As BPman says 'Have you finalized the disk?'
I would use windows media player. ![]() |
Yes .... "Finalise Disk" is set to "yes" .... Best Regards, Axel |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Axel, I cant help Im afraid, but on a more interesting note my home town of Sheffield is/was twinned with Bochum. The road around the corner from me is even called Bochum Parkway. I imagine your town of Bochum must have been so excited to be twinned with a Scheiße Loch like Sheffield!
![]() ![]() http://www.bochum.de/C125708500379A31/vwCo...Q185BOLDEN .... right next to the beautiful Peak District .... Best Regards, Axel |
