Home > Puma (Tdci) > Inside my Defender........AKA new clutch installed
dgardel
Italy
Gearbox complete:
Old Clutch disk, see the spring head....
Again
New clutch disk
Flywheel (like new 22.500 km Wink )
New clutch box with code (I checked it's the last revision)
Post #13110 20th Jul 2009 8:34am
Pauly
Germany 2007 Defender 110 Puma 2.4 SW Java Black
What is different? ... stronger springs only?
Just had my 2nd clutch replaced at 35000km. The first one was gone after 18000km.
Sad All science is either physics or stamp collecting. (E. Rutherford)
Post #13141 20th Jul 2009 4:19pm
dgardel
Italy
Yes, new spring materials (new color code).
Like you can see, the friction material and the flywheel are in perfect condition.
You must now that my engine was remapped and it produce 47kmg of torque (480Nm).
Bench tested.......
Post #13147 20th Jul 2009 7:53pm
dgardel
Italy
This morning I just drove for 489 km................
all ok...................
Post #13181 21st Jul 2009 12:23pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
What symptoms caused the replacement(s)?
Post #13189 21st Jul 2009 3:15pm
dgardel
Italy
loud rattle at the engine switch on or off (without pressing the clutch)
Post #13194 21st Jul 2009 5:24pm
Eduardo
dgardel,
Good to see that you have a new clutch installed.
In mine, one of the springs went out completely leaving us in the middle of a rural road in the night with all the family inside.
Cheers Eduardo
Post #13198 21st Jul 2009 6:14pm
dgardel
Italy
Shocked Big Cry
Post #13200 21st Jul 2009 7:25pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
did you have any laboured rattles in 6th under load??
Post #13201 21st Jul 2009 7:27pm
dgardel
Italy
No, no rattle at all
Post #13206 21st Jul 2009 11:49pm
