Home > Maintenance & Modifications > Varying results with headlight upgrades |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Can I just make a plea for people NOT to install HID? They WILL dazzle people coming the other way which is a massive problem if you're on a motorcycle. If means you can't see the road surface in front of you so whereas a car can easily go over a slippery manhole cover on a corner, in the dark with headlamp dazzle in that situation a bike is highly likely to crash. So PLEASE do not covert your LR to HID.
Bulb replacement is extremely effective and already covered in this thread. I cannot understand the utter obsession that Land Rover owners have for wanting to light up the scenery like they're in a Bond movie. It's bloody ridiculous and dangerous. |
15th Mar 2012 6:29pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
The good old light debate!
There are literally hundreds of light emitting devices available for use with Defenders be it LED work lights HID headlamps etc etc. What amazes me is that so many of the lights available do not give the basic bit of information which is essential for lights and that is the actual light output from the device. The power consumed by the unit be it 6/21/5/75/100 watts IS important for working out cabling/fuse/relay size but has no direct relevance to actual light output or range. Lightforce lights and the J W Speaker lights are a couple of manufacturers who do give a measurement of light output. When lumens are mentioned are the manufacturers talking raw or effective lumens? Candela or candlepower. I for one will be happier when all light manufacturers gives out realistic effective lumen figures. and on an acceptable industry standard Then there is the IP rating or Ingress Protection rating for dust and water. A lot of the work lights etc do not have an IP rating, how often have you seen lights more akin to goldfish bowls? As for the Defender light switch issue on our recent trip we picked up a couple of these Have not had a chance to play with them yet Brendan Last edited by leeds on 15th Mar 2012 7:27pm. Edited 1 time in total |
15th Mar 2012 6:45pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 619 |
Brendan
That looks great. If I understand the translation of the website correctly, it is also available with wiring for auxiliary lamps. Would that allow auxiliary lights to be wired so they come on with main beams? I look forward to seeing how you get on with this. |
15th Mar 2012 7:12pm |
mudrut Member Since: 29 Feb 2012 Location: Stourport-on-Severn Posts: 80 |
Mein Deutsch ist nicht so gut, aber ich benutze diese.......
ARB Headlight Upgrade Loom Ian |
15th Mar 2012 7:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Has anyone ever tried a 130w spot?
15th Mar 2012 7:31pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
I had on a previous LR 90 IPF 170/100watt Headlamp conversion kit.....
Click image to enlarge HIGH BEAM Click image to enlarge HIGH BEAM WITH LIGHTFORCE LIGHTS ON Click image to enlarge 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
15th Mar 2012 7:52pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
Probably a 4000K HID is a good choice. White enough and long lasting bulbs. Uprated H4 bulbs (Philips, Osram, PIAA, etc) have very limited life. IMHO Puma 110" SW
15th Mar 2012 8:43pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
I seem to remember somebody said "god-like" when I lit up crossing the Arctic Circle |
15th Mar 2012 9:11pm |
Uprated H4 bulbs (Philips, Osram, PIAA, etc) have very limited life. IMHO[/quote]
True, But I don't drive at night very much so it doesn't worry me too much. |
15th Mar 2012 9:41pm |
