Home > Td5 > Thermostat change
jwhat
Ireland 2008 Defender 110 Puma 2.4 DCPU Keswick Green
Thermostat change
Hi Guys, Does anyone have a how to guide for the thermostat? OR can explain it for me please?
Truck is running a little cold lately Tdci 110 DC
Post #131621 15th Mar 2012 5:33pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
Probably a bit late, but its really easy. Just follow the notes in the workshop manual.
Quick replacement guide:
Remove Rad Quick Release Panel.
Remove Engine Cover
Remove Fan.
Drain Anti-freeze at Radiator lower hose (offside).
Using suitable tool (pliers/water pump pliers) remove the 3 hose clips on the 3 hoses into the Thermostat.
Remove Thermostat
Fit new Thermostat by connecting hoses and securing with clips. Make sure Thermostat is located correctly.
Make sure all hoses are connected and routed correctly.
Refill and bleed the system.
Then refit removed ancilleries.
Run engine and check for leaks.
Thats very basic, but a good starter for 10.
Best top tip I can give is to buy a bleed hose screw before you start the job. They are about £3 and will save a lot of problems if you snap the bleed screw!
Chan Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #136365 2nd Apr 2012 7:36pm
jwhat
Thanks for that Chan, I haven't actually got round to doing it yet, it's down for doing next weekend,
Thanks for the tip with the bleed screw, I'll add it to the list. Tdci 110 DC
Post #136525 3rd Apr 2012 3:17pm
jst
its the same as a td5, google that. i didnt think you could get different thermostate rates though for them? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #136548 3rd Apr 2012 4:20pm
jwhat
I'd hope my Td5 is the same as everyone elses! Laughing
There is only one rate as far as I and the parts guy know. Tdci 110 DC
Post #136572 3rd Apr 2012 4:57pm
jst
sorry, i had assumed you had a puma. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #136720 4th Apr 2012 6:10am
changill
Hardest bits are getting the fan off and those stoopid hose clips. The hoses are different diameters and have different size clips. make sure you have suitable size pliers for all the clips before you start the job!
Good Luck
Post #136766 4th Apr 2012 11:18am
jwhat
Ah ok that makes sense.
Good Luck
Chan
Thanks again Chan, I'll check the hoses before I start, don't like having to walk to the toolshop/motorfactors for things I forgot Embarassed Tdci 110 DC
Post #136800 4th Apr 2012 1:07pm
jwhat
What a crap job to do. I don't think the coolant was ever changed in her and them stupid clips were out to ruin my day! But I got done in the end.
After about 5 minutes driving (after bleeding) the temp gauge looks like this and it didn't increase anymore.
Is that too low or is that the standard Td5 temp?
It wasn't too cold out last nite, maybe 4/5 deg celcius and I gave it a good run to try and get it warmer.
The heater definately works too (so i presume I bled it properly)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tdci 110 DC
Post #139537 16th Apr 2012 10:43am
excossack
The needle in my temp guage sites more towards the logo in the middle of the dial 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #139539 16th Apr 2012 10:48am
Mine's the same too. The needle is probably about half the distance from the logo as is shown on your picture. That could just be a consequence of you renewing the coolant though and if you've got heat from the heater and it isn't over-heating generally then I wouldn't be too concerned. Darren
Post #139541 16th Apr 2012 10:53am
landy andy
As above mine sits little higher, but as you said it was only 4-5 degrees think its ok Thumbs Up
Andy
Post #139543 16th Apr 2012 11:00am
jwhat
That's ok then, thatnks for putting me at ease lads. Thumbs Up Tdci 110 DC
Post #139546 16th Apr 2012 11:05am
changill
Sorry to hear it was a pig. The clips are the hardest,eh?
From your pic I would say that it still has some air in their somewhere. Mine sits a bit higher and others I have seen also sit higher.
If your running lower than norm your engine won't be as efficient as it could be.
Did you put the heater knobs to full heat when topping up?
Up to you, but if it was mine I would be bleeding it again.
Post #139649 16th Apr 2012 7:46pm
jst
my td5 ran with the temp gauge vertical. as did all the other td5 defenders i drove through work or otherwise.
if its cold ambient and the heater is on full it can take a while to warm up, around 0 deg mine used to take forever to get to normal temp with heater on max.
temp on mine would also drop from vertical if sat in traffic in near 0 with heater on max.
viscous works as it should i take it? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #139653 16th Apr 2012 7:52pm
