Home > Maintenance & Modifications > Defender 90 LED bulb list?
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi, does anyone have slits of LED bulb types for all interior and applicable exterior application?
Many thanks.
Post #131318 14th Mar 2012 4:05pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Headlight. H4 12v 100w /80w
SideLight. 207 12v 5w
Indicator. 581. 12v 21w
Stop/Tail. 380. 12v. 21w/5w
Numberplate. 233. 12v4w
The codes are for the shape of bulb, so they should be the same for an LED type. The wattage will be different, but you shoudl be able to find LED bulbs of equivalent power....
http://www.autobulbsdirect.co.uk/581-PY21W-led-bulbs/
The above link is for 581 bulb. Just do the same for each type and shop around...
Hope this helps.
Post #131321 14th Mar 2012 4:26pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
try UltraLeds..
www.ultraleds.co.uk
I've had good service from them.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #131326 14th Mar 2012 4:49pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Hope this helps.
382 is the standard indicator bulb [for the majority of 90/110 models] .... 581 is the yellow coated one with offset pins, Guns and Landrovers .... anything else is irrelevant.
Post #131328 14th Mar 2012 4:53pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
They're H4 60w/55w as fitted at the factory. You can get H4 100w/80w but the headlight switch on a Defender melts easily enough as it is. I even carry a spare one now; they never fail in daylight Rolling Eyes Dave
Green Goddess - 1998 Defender 110 300tdi
Post #131350 14th Mar 2012 7:29pm
Mike_B
Never had a problem with mine....... (cue melting switch!)
Post #131365 14th Mar 2012 8:23pm
nosnibod
I've melted two so far. Always in the dark, strangely Rolling with laughter
Hence the spare... Dave
Post #131385 14th Mar 2012 9:04pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
melting headlight switch is a worry. can you advise part number please, piccy? thanks BM52
Post #131398 14th Mar 2012 9:28pm
nosnibod
Here you go. Part number is AMR6104. Dave
Post #131410 14th Mar 2012 9:46pm
bm52
Thanks, I normally drive on dips so i suppose it could happen at any time.
Just looked on lrseries web site, what a difference in price. Genuine -£108. Pattern £21 Shocked BM52
Post #131412 14th Mar 2012 9:50pm
nosnibod
I got a pattern part from Roeans in Telford - about £30 if I remember and it came in a Lucas box. Not sure if that's a good thing Rolling with laughter Dave
Post #131413 14th Mar 2012 9:53pm
bm52
just oredered one, last thing i want is for the switch to go in wilds of south france Shocked
cheers BM52
Post #131423 14th Mar 2012 10:22pm
esc
2014 Defender 90 Puma 2.4 SW Havana
Re: Defender 90 LED bulb list?
Many thanks.
i have a pdf list of this:
LED Bulb Data
Location Color Part # Source # Off Unit $ Total $ Sylvania Alt
Front Parking Amber 67-A15 superbrightleds.com 2 $4.95 $9.90 5007 67
Front side marker Amber WLED-A6 superbrightleds.com 2 $2.79 $5.58
Rear side marker Red WLED-R6 superbrightleds.com 2 $2.79 $5.58
Tail/brake Red 1157-R24 Wide superbrightleds.com 2 $7.49 $14.98 7528 1157
Front/Rear Signal Amber 1156-A24 Wide superbrightleds.com 4 $7.49 $29.96 7506 1156
Back up (reverse) White 1156-W24 Wide superbrightleds.com 1 $12.99 $12.99 7506 1156
Licence Plate White BA9S-W4-12V superbrightleds.com 2 $2.98 $5.96
3rd Brake Light Red WLED-R6 superbrightleds.com 3 $2.79 $8.37 2825
Interior Light White 4410-NW9? superbrightleds.com 1 $4.74 $4.74 6411
Shifter Illum White WLED-W6? superbrightleds.com 2 $2.79 $5.58
Speedo Illum Green B8.5D-GHP superbrightleds.com 2 $2.59 $5.18
Fuel Illum Green T13-G6 superbrightleds.com 1 $2.99 $2.99
Temp Illum Green T13-G6 superbrightleds.com 1 $2.99 $2.99
Tach Illum Green 74-G superbrightleds.com 1 $1.19 $1.19
Hazzard Illum Green 74-G superbrightleds.com 1 $1.19 $1.19
Hazzard On Red 74-R superbrightleds.com 1 $1.19 $1.19
Heat Switches Green 74-G superbrightleds.com 2 $1.19 $2.38
Warn Lamps White 74-W superbrightleds.com 15 $1.19 $17.85 T5 (74)
Flasher Realy N/A EP26 autolumination.com 1 $19.95 $19.95
$138.60
= Not sure as I haven't changed these ones so the part # is a guess.
= Potentially a better bulb than what I fitted but I haven't tried it yet so can't confirm.
(looks better on PDF)
it's for a D90 MY'97 NAS
it might be the same as what you looking for
email me if you need the PDF list
Eric
ephernandez@gmail.com
Post #131463 15th Mar 2012 3:04am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Renewing old thread..
Apologies for digging up an old thread - found it useful in thinking upon retrograde LED lamp fitting.
Found the following at abd.co.uk - they also have a nifty model to demonstrate both OEM & LED bulbs for your Defender.
Front side lights - BA15s SCC (207)
Rear numberplate lights - BA9s (233)
Rear indicators, foglamp, reversing lamp - BA15s (382)
Front indicators ("offset pin") - BAU15s (581)
Rear stop- and taillamps combination - BAY15d (380)
Post #611755 24th Mar 2017 7:26am
leeds
Obligatory vehicle lights have to be type approved which these days means E marked.
The approval is to how the light was tested and supplied by the original manufacturer. So if a standard filament bulb was originally in the fitting then that was what the type approval is for. Put a LED in and the type approval
Is void as it is an unapproved modification which the original manufacturer has not tested. As such those lights are ILLEGAL and are not allowed to be used on the public highway.
Brendan
Post #611761 24th Mar 2017 9:00am
