![]() | Home > Maintenance & Modifications > Defender 90 LED bulb list? |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Headlight. H4 12v 100w /80w
SideLight. 207 12v 5w Indicator. 581. 12v 21w Stop/Tail. 380. 12v. 21w/5w Numberplate. 233. 12v4w The codes are for the shape of bulb, so they should be the same for an LED type. The wattage will be different, but you shoudl be able to find LED bulbs of equivalent power.... http://www.autobulbsdirect.co.uk/581-PY21W-led-bulbs/ The above link is for 581 bulb. Just do the same for each type and shop around... Hope this helps. |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
try UltraLeds..
www.ultraleds.co.uk I've had good service from them.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
382 is the standard indicator bulb [for the majority of 90/110 models] .... 581 is the yellow coated one with offset pins, Guns and Landrovers .... anything else is irrelevant. |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
They're H4 60w/55w as fitted at the factory. You can get H4 100w/80w but the headlight switch on a Defender melts easily enough as it is. I even carry a spare one now; they never fail in daylight ![]() Green Goddess - 1998 Defender 110 300tdi |
Never had a problem with mine....... (cue melting switch!)
I've melted two so far. Always in the dark, strangely
![]() Hence the spare... Dave Green Goddess - 1998 Defender 110 300tdi |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
melting headlight switch is a worry. can you advise part number please, piccy? thanks BM52
Here you go. Part number is AMR6104. Dave
Thanks, I normally drive on dips so i suppose it could happen at any time.
Just looked on lrseries web site, what a difference in price. Genuine -£108. Pattern £21 ![]() |
I got a pattern part from Roeans in Telford - about £30 if I remember and it came in a Lucas box. Not sure if that's a good thing
just oredered one, last thing i want is for the switch to go in wilds of south france
![]() cheers BM52 |
esc Member Since: 19 Oct 2011 Location: Philippines Posts: 4 ![]() ![]() |
i have a pdf list of this: LED Bulb Data Location Color Part # Source # Off Unit $ Total $ Sylvania Alt Front Parking Amber 67-A15 superbrightleds.com 2 $4.95 $9.90 5007 67 Front side marker Amber WLED-A6 superbrightleds.com 2 $2.79 $5.58 Rear side marker Red WLED-R6 superbrightleds.com 2 $2.79 $5.58 Tail/brake Red 1157-R24 Wide superbrightleds.com 2 $7.49 $14.98 7528 1157 Front/Rear Signal Amber 1156-A24 Wide superbrightleds.com 4 $7.49 $29.96 7506 1156 Back up (reverse) White 1156-W24 Wide superbrightleds.com 1 $12.99 $12.99 7506 1156 Licence Plate White BA9S-W4-12V superbrightleds.com 2 $2.98 $5.96 3rd Brake Light Red WLED-R6 superbrightleds.com 3 $2.79 $8.37 2825 Interior Light White 4410-NW9? superbrightleds.com 1 $4.74 $4.74 6411 Shifter Illum White WLED-W6? superbrightleds.com 2 $2.79 $5.58 Speedo Illum Green B8.5D-GHP superbrightleds.com 2 $2.59 $5.18 Fuel Illum Green T13-G6 superbrightleds.com 1 $2.99 $2.99 Temp Illum Green T13-G6 superbrightleds.com 1 $2.99 $2.99 Tach Illum Green 74-G superbrightleds.com 1 $1.19 $1.19 Hazzard Illum Green 74-G superbrightleds.com 1 $1.19 $1.19 Hazzard On Red 74-R superbrightleds.com 1 $1.19 $1.19 Heat Switches Green 74-G superbrightleds.com 2 $1.19 $2.38 Warn Lamps White 74-W superbrightleds.com 15 $1.19 $17.85 T5 (74) Flasher Realy N/A EP26 autolumination.com 1 $19.95 $19.95 $138.60 = Not sure as I haven't changed these ones so the part # is a guess. = Potentially a better bulb than what I fitted but I haven't tried it yet so can't confirm. (looks better on PDF) it's for a D90 MY'97 NAS it might be the same as what you looking for email me if you need the PDF list Eric ephernandez@gmail.com |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Apologies for digging up an old thread - found it useful in thinking upon retrograde LED lamp fitting.
Found the following at abd.co.uk - they also have a nifty model to demonstrate both OEM & LED bulbs for your Defender. Front side lights - BA15s SCC (207) Rear numberplate lights - BA9s (233) Rear indicators, foglamp, reversing lamp - BA15s (382) Front indicators ("offset pin") - BAU15s (581) Rear stop- and taillamps combination - BAY15d (380) |
Obligatory vehicle lights have to be type approved which these days means E marked.
The approval is to how the light was tested and supplied by the original manufacturer. So if a standard filament bulb was originally in the fitting then that was what the type approval is for. Put a LED in and the type approval Is void as it is an unapproved modification which the original manufacturer has not tested. As such those lights are ILLEGAL and are not allowed to be used on the public highway. Brendan |
