Home > Maintenance & Modifications > XS Carpet Removal
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
XS Carpet Removal
Hi All
Can't seem to find anything about this in a search (probably being thick)
I want to remove some of the carpets in an XS (to fit wiring) and wasn't sure how they are fixed to the floor. Looks like a sort of plastic clip in thing, how is it best to remove these without breaking them (done that before on doors and needed to get new clips Big Cry )
I'm guessing from previous posts that the flat ones in the rear and around seats are double sided tape but the fronts appear to have a proper fixing.
Any suggestions please I'd be grateful as I don't want to get it wrong.
Ta
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #131302 14th Mar 2012 2:49pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
The front carpets are held in by two clips onb either side - they fix into plastic grommets in the floor - just pull straight out - if you damage them they're only pence to replace. Rear carpets on side are indeed held with sticky tape so just pull off. If removing/lifting rear floor carpet may need to remove strip at rear door first. Might be trickier if you have rear seats, mine doesn't.
Post #131308 14th Mar 2012 3:25pm
d j hutton
Cheers Cobs, I had a feeling it would be straightforward, I'll give that try when it's not dark out.
Only need to remove front and first passenger carpet to wire in a subwoofer.
Something for the weekend sir I think.
Ta
Dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #131346 14th Mar 2012 7:22pm
d j hutton
Ta
Buy British 🇬🇧
Post #131349 14th Mar 2012 7:28pm
110SEB
The plugs and grommets will probably break. In the front I've removed our carpets since they're just sponges. I've put gaffer/duct tape over the holes in the floor and the rubber mats fit on top. Much less cabin moisture in winter now.
Post #131367 14th Mar 2012 8:31pm
Projectblue
Are they the normal trim fit round clips? If so simply buy a trim tool from a tool upply place and you can extract them intact and refit. Works on all trim - e.g. door cards.
Post #131457 14th Mar 2012 11:43pm
