Home > Puma (Tdci) > tapping puma engine
boxer
United Kingdom 1990 Defender 90 200 Tdi HT Coniston Green
tapping puma engine
Not sure but i think my engine is getting more tappy, its more noticable when driving at low speeds with a small amount off acceleration i have just done 1500 miles since new.Is this normal engine noise or should i be concerned.
Post #127760 29th Feb 2012 6:17pm
wslr
Put some fuel conditioner in the tank to quieten it down.
Post #127766 29th Feb 2012 6:27pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Mine is the same at times ..... no pattern to it, some days it 'taps' more then others ... i blame fuel quality myself, dunno if im right though Confused Guns and Landrovers .... anything else is irrelevant.
Post #127809 29th Feb 2012 8:09pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Just need to alter the advance of the pilot injection a little between 1000 - 1500rpm at light to medium engine loads.
I could also ease the fuel pressure set points around these areas too. Wink
Post #127813 29th Feb 2012 8:24pm
boxer
Think you could be right about fuel quality i started with bp fuel then jet and now morrison's filled up 2 days agone think its worse with morrison's fuel.I have read the posts regards adding 2 stroke oil etc but i am suprised how temperamental the engine seam's.
Post #127815 29th Feb 2012 8:28pm
Alive Tuning
Fuel quality and cetane value matter, when it comes to keeping your engine quiet, and clean. 2 stroke works brilliantly!
Post #127820 29th Feb 2012 8:32pm
boxer
Thanks for the info guys might start adding 2 stroke oil what mix is best and what make ?
Post #127822 29th Feb 2012 8:37pm
bolampau
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
as per recommendation from this forum I use:-
http://www.opieoils.co.uk/p-928-motul-100-...gines.aspx
Cheers,
Paul
Post #127824 29th Feb 2012 8:42pm
Alive Tuning
I currently use Carlube 2 stroke, the red stuff. You don't need much, as a small bottle should last quite a few tank fulls, depending on the size of your tank of course.
I put half a 250ml bottle in my TDV8 at a filling station earlier today, and got asked what I was doing by the bloke there.
Post #127827 29th Feb 2012 8:50pm
spudfan
Ireland
If you are in Tesco pick up some of their 2 stroke motor cycle oil oil. It is mineral based to FB standard which is good enough for the 2.4 Puma. Use 250 ml or 1/4 litre per tank.
If you have a 2.2 Puma use FC spec 2 stroke owing to the DPF. fitted.
Have been using 2 stroke at every fill up. Does not increase mpg appreciably but keeps everything smooth and quiet. Good for your emissions too. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #127828 29th Feb 2012 8:51pm
boxer
cheers paul have you noticed a difference using the oil
Post #127829 29th Feb 2012 8:51pm
bolampau
Yep, seems quieter and I add it at the rate of 250 to 300ml per tank. I buy Sainsbury's diesel as it's cheaper and the 2SO makes a difference.
Post #127831 29th Feb 2012 8:56pm
boxer
I will start adding tomorrow and report back cheers guys
Post #127832 29th Feb 2012 8:56pm
AlpsLandy
France
I have the same tapping with 1000 miles on the clock. Only bought fuel from Esso station but it is located at a supermarket... Most of my diesel driving neighbors use 'additives' but I thought no need if it's proper branded (additives included etc) fuel, maybe it isn't... Will try the 2SO trick - top tip, cheers. 2011 Defender 90 SW
2006 Discovery 3 HSE
Post #128363 3rd Mar 2012 10:46am
affiliate13
2012 Defender 90 Puma 2.2 HT Sumatra Black
Would this be suitable for 2.2 Pumas?
http://www.carlube.co.uk/index.cfm?product=78
I was reading in another thread here that it should be mineral based JASO-FC?
Post #128382 3rd Mar 2012 12:51pm
