![]() | Home > Td5 > Best oil for high mileage manual gearbox (r380) |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
Alternatives are discussed here:
http://www.defender2.net/forum/topic7888.html No idea if the stated info is correct though. ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
I'd stick with the Havoline/Texaco MTF94 as stated by Land Rover.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
Difflock stuff is great
![]() ![]() Don't bother putting it in your diff's tho, not worth it. Andy |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Difflock supply fully synthetic gear oils at an inflated price.
You require: MTF 75w80 GL4 for the gearbox 75w90 gear oil for the diffs/ transfer box GL5 Morris oils make Lodexol oil suitable for the gearbox (R380 specific)/ also Fuchs sintofluid is available as an alternative (from memory its GL5) Fully synthetic gear oil 75w90 is readily available any make ok. I would use fully synthetic oil for gearbox/ transfer box. Can use semi syn for diffs and change annually. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
Motul Gear 300 (fully synthetic) has resurrected two of my old gearboxes - one in a 1974 VW Beetle and the other in a 2003 Audi with synchro problems. It's a bit pricey but I've been seriously impressed.
In retrospect, don't use additives unless as a last resort! Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
MTF is actually cheapest from your Land Rover dealer in 1ltr bottles, i just had a big search for the stuff for my Range Rover and its the genuine stuff. £6.30ltr If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
Ok thanks all, not sure what to go for but the job will get done ASAP
Cheers again ![]() |
For the general record, in the last 2 years we had 2 R380's which didn't like the Morris Lodexol, despite the specs about being R380 friendly. One was in a P38, the other a Discovery2. Morris technical gave us the blurb about it being developed with LR in the Sahara. ![]() Just use the MTF94, or spend out on something else mentioned here already. |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
I had the same thing on my TD5 defender. Now running genuine oil and everything is ok again. I have changed my gearbox oil every 12k from new though, im sure it has helped a lot. Pete |
Still doing some more research, I like the thought of a fully synthetic oil but don't like the price of the diff lock evo stuff.
Spotted this from: Liqui Moly. Fully synthetic gear oil (GL 5) SAE 75 W 90. £6.90 per litre Looks ok to me ![]() ![]() ![]() Price looks very good to me for fully synthetic gear oil ![]() Last edited by amondeggs on 4th Mar 2012 5:43pm. Edited 2 times in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6636 ![]() ![]() ![]() |
Equivalents to Difflock oils: http://www.defender2.net/forum/topic7888.html?highlight=fuchs
in my 300tdi, the 4th gear was almost impossible to select when cold, as soon as it had warmed up it was fine. I spoke to Dave Ashcroft and he suggested the evo oil, works a treat. not tried evo in the diffs but Im going to when the time comes.
