Home > Maintenance & Modifications > Black chequer plate |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
what about the matting that looks like chequer plate?
28th Feb 2012 8:50pm |
Skippy R Member Since: 08 Feb 2012 Location: Yorkshire,out 'n'about Posts: 160 |
Where do you get that Dave 98 'S' 90 300Tdi (sold) 07 D3 HSE (now sold) 1993 Scania 143 450 (should have kept that ! ) |
28th Feb 2012 9:04pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2635 |
Hi Skippy
There is a feature in this months LRM Accoustic matting from Wright Off-Road with a black chequer plate pattern Mark |
28th Feb 2012 9:08pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Buy ordinary checkerplate and have it black anodised.
That way, the cut edges are also black. |
28th Feb 2012 9:11pm |
I used stable matting - the advantage is sound proofing and it can be hosed out
available from mole valley farmers - just down the road |
28th Feb 2012 9:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20358 |
Not sure rubber would be suitable for my use but I know the stuff you mean. I never thought about the edges on hindsight your right because when cut the edges would be silver. So you think the best idea would be to get regular chequer cut to size and then have it anodised. Where best do you think to get the chequer plating? Rebel 4x4?
28th Feb 2012 10:15pm |
Check your local non-ferrous metal stockist. That would be the cheapest way.
May be listed as 'treadplate'. |
28th Feb 2012 10:22pm |
Cheers Mark I'll have a look at that. Was wanting to do something under my seats but it must be in black, only as a bit of extra noise reduction etc. Dave
28th Feb 2012 11:09pm |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Contact Patriot, as in the guys who make roof racks.
A mate said he had loads of it in stock, could be cheeper. |
29th Feb 2012 10:33am |
Thanks for the info all of you. At least it's only square cut pieces and not shaped and also flat so shouln't be to bad.
29th Feb 2012 11:14am |
