Home > Puma (Tdci) > Bleeding a TDCi? |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Any body know how you do it and what tools you will need to carry with you in case you run out of fuel?
Thanks |
5th Jul 2009 8:03pm |
Andrew388 Member Since: 25 Feb 2009 Location: Westen Cape Posts: 9 |
What I have done a couple of times in the past is this: detach fuel pipe at coupling under the bonnet, nearest to the firewall. Pressurise the fuel tank slightly, which will force fuel through the fuel lines and bleed the air out.
I use my tyre compressor, wrapped with plastic at the end and inserted into the tank filler. I then give the tank a little blast of air, which is generally enough to bleed the system. Once the fuel is flowing out of the coupling freely I reconnect and the start the car. I have used this method after running out of fuel and when changing diesel filters. |
6th Jul 2009 7:03am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Thats right Tim re ecu not letting you run out, same on the Jag's 2.4 90 XS
6th Jul 2009 8:25am |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 |
very interesting. Ive been meaning to ask this question myself for some time now
Could I make up a pump myself with a boat fuel hand pump and standard high pressure hose with a one way valve??? Land Rover's don't leak oil, they simply mark their territory! |
6th Jul 2009 10:51am |
Thanks guys, very helpful.
Any idea what the procedure is for bleeding it? i.e. what goes where and what you do and in what order. Thanks |
6th Jul 2009 5:05pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
We have covered this hang on. Ill Be Back
6th Jul 2009 7:09pm |
6th Jul 2009 7:14pm |
