![]() | Home > My Defender > My 2000 td5 90 project |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Disco 2 axles?
marsie Member Since: 17 Nov 2011 Location: sheffieldish Posts: 532 ![]() ![]() ![]() |
yep D2 axles modded to fit defender links. Also building a 100" on a custom chassis using all D2 link bars including rear watts linkage
Sounds good, keep the photos coming!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Jigs made for each axle and all bracketry welded into place. Axle casings now away at sandblasters. Hopefully pick up tomorow ready for painting and rebuilding. Currently stripping and rebuilding diffs,brakes and replacing cv joints ready for rebuild ![]() Paul :mrgreen: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Axle casings all sandblasted and coated with a thick coat of Jotun conseal paint. Also got my rear NAS step blasted and galvanised :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Axles fitted. Modified Rear shock turret to take d2 shocks. Just need to swap the tyres now ![]() Paul :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
No probs Steve,done a few D2 axle conversions now so i guessed it was time to build a couple of jigs so that the guesswork was taken out of the equation
Another job completed today. Have cranked my front arms to give the correct caster to suit the 2"lift. One problem with fitting the new axles is that they really show up negative or zero caster resulting in VERY twitchy steering. This combined with the silly little wheels made motorway work very nervous
![]() So off came the front arms and the caster angle adjusted with a 200t hydraulic press to 3degrees ![]() ![]() Pick my 285s up next week and cant wait to get them on Paul ![]() |
new boots fitted today
![]() thanks to TTF ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
aaronmorris Member Since: 03 Sep 2010 Location: doncaster Posts: 62 ![]() ![]() ![]() |
looking good mate
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 ![]() ![]() |
Hi marsie have you done any more to it ??
Nowt much Derrick, got a new chassis and rear tub ready for it when i get the chance but not a lot else
Decided to bite the bullet on saturday and re-chassis my 90 while i am quiet at work. In the process i have set a new personal best for a chassis swap-12 hours
![]() in the process i also re-aligned the props and have got rid of my vibrations ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Paul :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
that is so impressive..........
