Home > For Sale & Wanted > Wanted air con condenser (rad)
landy andy
Need an air con condenser, rad thing.
Td5 04 reg
Any ideas, offers
Thanks
Andy
Post #125890 22nd Feb 2012 2:17pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Has yours corroded and started to fall apart? I looked for one about a year ago and ended up buying a new one, not cheap. Big Cry
Post #126007 22nd Feb 2012 10:07pm
landy andy
Just got alien blood pouring out over the bumper.
But it's not in it's first youth, so need replacement. Will continue to look, although other option is removal of the air con.
I will NOT spend £600 on air con part, before all the Censored about. Big Cry Big Cry
Andy
Post #126010 22nd Feb 2012 10:17pm
yobbie
I had a new rad. as that was corroded, falling apart at the bottom, a new fan belt as that looked pretty worn & the condenser fitted for about £800. I had not long bought the 90 and took the grill off to find all the rads falling apart including the Intercooler, replaced that with an IRB one. Don't know if it's a common problem with the rads corroding and falling apart (although mine was 12 years old) but I do tend to give the rad a hose down while the salt is out on the roads to hopefully prevent it from happening again. Would much rather do it now than have problems miles away from home.
Post #126019 22nd Feb 2012 10:42pm
