Home > For Sale & Wanted > Wanted air con condenser (rad) |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Has yours corroded and started to fall apart? I looked for one about a year ago and ended up buying a new one, not cheap.
22nd Feb 2012 9:07pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5785 |
Just got alien blood pouring out over the bumper.
But it's not in it's first youth, so need replacement. Will continue to look, although other option is removal of the air con. I will NOT spend £600 on air con part, before all the about. Andy |
22nd Feb 2012 9:17pm |
I had a new rad. as that was corroded, falling apart at the bottom, a new fan belt as that looked pretty worn & the condenser fitted for about £800. I had not long bought the 90 and took the grill off to find all the rads falling apart including the Intercooler, replaced that with an IRB one. Don't know if it's a common problem with the rads corroding and falling apart (although mine was 12 years old) but I do tend to give the rad a hose down while the salt is out on the roads to hopefully prevent it from happening again. Would much rather do it now than have problems miles away from home.
22nd Feb 2012 9:42pm |
