Home > Maintenance & Modifications > Another little step for have a 100% LED equipped Defender |
Click image to enlarge Click image to enlarge Next step: Use the original side lights (the quality LED from JW Speaker need to be fixed from the "internal" side of the Defender body, good for the rear lamps but problematic if you want to remove the front ones) equipped with good LED bulbs and sealed with silicone sealant (so you can salvage the side lights because the silicone can be easily removed). Photos will came..... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd Feb 2012 8:56am |
Yes I know, but if you need to remove the headlamp surround you need to remove the plastic cover inside the front wing for release the side light..... In my opinion JW Speaker are THE BEST (I have the 8700 headlamps installed)...... If my experiments will fail I'll install the JWS...... The FOG and REVERSE lights are made from WIPAC, a good realization!! not cheeper!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd Feb 2012 10:27am |
