Home > Maintenance & Modifications > Wiring Wipac SVX lights? |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
That's what I did with mine, just chained them off the sidelight. Naughty I know, but the total draw is something like 0.75A on a wire that's already well oversized.
21st Feb 2012 12:00pm |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 |
Thanks - I'm planning on replacing the SVX internal sidelight with an LED bulb and the existing sidelight with a 207 LED bulb, do you know if that will work?
21st Feb 2012 12:09pm |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
That will work fine, the LED lamps will reduce the current below that of one normal bulb anyway.
21st Feb 2012 12:50pm |
Thanks Guys!
21st Feb 2012 1:50pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Don't do it. The heat generated by the main/dip beam inside the enclosure will take the LED sidelight way outside it's operating temperature spec. It will not survive very long. The LED in the existing external side light will be fine. Pete |
21st Feb 2012 2:49pm |
Thanks Pete
21st Feb 2012 2:54pm |
No problem. I made this mistake so you don't have to!
Pete |
21st Feb 2012 3:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
The Main bulbs go upto something like 220'C if I remember correctly
21st Feb 2012 4:09pm |
Too true, and a standard 5050 SMD LED is operating outside its comfort zone above 85C.
Pete |
21st Feb 2012 4:19pm |
Easy to not realise though! LED type bulbs also tend to be plasticky often too. Personally I don't like LED's seem too directional on light output to me |
21st Feb 2012 4:44pm |
Thanks for all your help:)
22nd Feb 2012 12:04pm |
