Home > Puma (Tdci) > Magnetic Drain Plugs |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
so, just to check,
no one has a magnet option for the engine oil or gear box? filtermag was mentioned but is no good, due to the plastic filter housing on the puma. |
30th Jan 2012 10:33pm |
for any one who is interested,
I have ordered a new drain plug for my Puma engine and will be using it to get the correct size magnetic drain plug from these guys http://www.magneticoildrainplugs.co.uk I will post a result of whaich size and if it fitts well once I have it, thought this may help some one Mark |
15th Feb 2012 11:26am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
It appears some have magnetic plugs on their gearbox but not the transfer box Usual parts inconsistency at the factory then |
15th Feb 2012 12:56pm |
got a sump plug (thanks duckworhts for good value once again) in the post last night, sized it via my local friendly engineers and have now ordered an M14 X 1.5 pitch magnetic plug from these friendly people
http://shop.motorsport-developments.co.uk/...-343-p.asp If you call them ask for Steve, he was very helpful, tell him Mark sent you P.S. this is the size for the 2.4 puma engine, don't know about any others. HTH Mark |
17th Feb 2012 4:04pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
You'd have thought that landrover might just have had an idea when they decided to put a magnetic one for the box and decided the others didnt need one. What do you know better that landrover doesnt?
17th Feb 2012 9:21pm |
Hydrocarbons (oils) and warm destroy 99% of glues....... If you loose the magnet and it sticky on gears you can broke all the gears!!!!! Put the magnetic plugs on transfer box and both the diffs..... Stay w/o mag plugs on gearbox and sump, it is better!!!!! Normally the magnetics plugs have a screw for fix well the magnet!!!! Or there are only few epoxy resin glues that resist at warm ad oils and it work with catalysator. And, normally, magnets have plain surface, very hard to fix with glue..... my 2 cents or use the double cab happy link ones..... On the sump I installed the quick drain plug from difflock, nice to change the oil w/o pain and w/o remove the entreq protection plate..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 18th Feb 2012 10:20am. Edited 2 times in total |
18th Feb 2012 10:16am |
All i know is that my transfair box had a little pile of metal filings on its mag plug when I did the oil change, I also know that filtermag will not work on the plastic filter case, and i know I will be keeping this vehical for a long time with any luck, so
I guess Im saying is, it can't hurt. Mark |
And, at least, on the engine sump it is not important to use a magnetic plug you have a filter on the circuit.
Magnetic plugs are good where you can't use a filter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
18th Feb 2012 10:23am |
Like I said, it's almost like Landrover and Ford know what they're doing
18th Feb 2012 11:01pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2432 |
On the outside of course
As I mentioned, there are 2 big magnets inside the gearbox casing to do the job. Really no need to add more. [quote="dgardel"]
Puma 110" SW ............................................................. Earth first. Other planets later |
19th Feb 2012 12:43am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
D C H
is the one you ordered from motorsport developments made by Magnetic oil drain plugs.co.uk ? are you happy with it? DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
19th Feb 2012 7:29am |
once I sized the delivered drail plug and called magnetic drain plugs I had missed there afternoon post for friday, so I'm waiting till tuesday to get my hands on it, re the thinking that "there is a filter for that" I'm going for the belt and braces, its a one of cost of less that £20, I just feel its worth a shot, and i only posted what I found as the OP was looking for one. Mark |
19th Feb 2012 7:45pm |
