Home > Technical > Knock from underneath |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Could be a shocker. 2.4 90 XS
27th Dec 2008 9:12am |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
Austen
Try applying the hand brake very slightly in the same conditions and see if produces the same symptons, if so it may the handbrake adjustment, I am told the return spring is being replaced as well as issues with drums. As the heat in the drive train builds up the handbrake catches the drum and you get a thump and knocking noise. |
29th Dec 2008 11:28pm |
austen Member Since: 10 Mar 2008 Location: Sydney Posts: 52 |
Thanks Sticky. I just tried pulling the handbrake on 1 click whilst driving and it seems to make the clonk (experienced when gear changing) worse. You may be onto the reason for the clonk!
The noise is still there - it's like someone knocking on the floor or the cubby box. Austen. |
31st Dec 2008 6:44am |
RgrBox Member Since: 04 Jun 2009 Location: St-Cergue, Switzerland Posts: 111 |
OK.. I'm having this same problem.. what did you do to correct this.. or is it a problem?
Mike B. 2008 110 2.4 tdci csw Landrovers of Switzerland Club member |
29th Jun 2009 2:28pm |
It turned out to be the bonnet hinge bushing. Took ages to locate the noise, but I remembered my old Series 11A made the same noise.
Austen. Rover 12 1935 Rover 20 1940 Rover 100 1960 Defender TDC1 2008 FL2 TD4 2008 |
7th Jul 2009 3:20am |
