Home > Puma (Tdci) > 2.2 motor still called Puma |
Because the engine IS THE SAME engine with 3,9 mm less of bore, but the engine is the same.........
little mods for DPF management (1800bar injection, HO2 sensor ......) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Feb 2012 9:04pm |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 |
@dgardel: why would keeping the name be normal? Is normal a valid vocabulary used in connection with things related to us old lunatics driving automobilistic dinosaurs? Even now with basically the same engine they could have chosen to name it Vroomfondel to keep us in the mood for the DC100 with its surely groundbreacking New Vroomfondel Engine For The Next Century, or short VNVEFTNC? Never forget: cars have owner, Landrover have field service personnel.
13th Feb 2012 4:18pm |
Puma is the code name for several Ford Duratorq engines of 2.0, 2.2, 2.4 liter. Including both the 2.4 and the "new" 2.2 now used in the Defender. So the name is correct.
Details here: http://en.wikipedia.org/wiki/Ford_Duratorq_engine You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
13th Feb 2012 4:32pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
I had an email from Haynes saying they have no intention of producing a manual for the 2.4 Puma Defenders anytime soon! See below... ===================================== Dear xxxxxxxxx Thank you for your recent enquiry regarding a Service and Repair Manual for your vehicle. Unfortunately, we do not produce a Manual for this particular model and have no plans to do so within the next 12 to 18 months. However, all customer requests are recorded and used in the decision making process of future Manual publications/updates. You could try contacting your local dealer to see if he can be of assistance. Kind regards Vicky Hall ====================================== ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
13th Feb 2012 5:35pm |
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 |
you can get a the Defender 2.4 "workshop manual MY 2007-on" online and download and keep on your labtop or make a copy on cd.
i did both so if i run into any trouble and can't fix it myself i can sill get the laptop out and show to the mechanic.. it has all part no's and Identification Codes on each chapter and detailed info on fixing and serviceing the TD4. It's in PDF form and has 1213 pages.... LANDROVER Defender Best 4 x 4 x Far Defender TD4 90 Hardtop 2.4 Defender TD4 110 Hardtop 2.2 |
13th Feb 2012 7:12pm |
If a problem doesn't have solution, why you are worry about it... If a problem have a solution, why you are worry about it, there is "dgardel" Workshop manual https://files.me.com/daniele.gardellin/eqyzbe Electric library https://files.me.com/daniele.gardellin/qm9sa8 Electric diagram https://files.me.com/daniele.gardellin/qi4tr7 Add-on for SVX, ROUGHT, FIRE & ICE https://files.me.com/daniele.gardellin/815mfz And I cost less than Haynes and Complete DTC code https://files.me.com/daniele.gardellin/vbutqe Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Feb 2012 7:32pm |
About the Puma codename you just have answer about it. BUT I REMEMBER TO ALL THAT LAND ROVER ARE USING THE 2.2 NOW BECAUSE FORD, FOR COST REDUCTION REASONS, HAD RATIONALISED THE PUMA ENGINE LINE UP WITH: 2.2L 3.2L ONLY!!!! On transit up to 2011, had the 2.4L with DPF in the same configuration of the 2.2.... look on the latest Transit RWD or 4WD..... Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Feb 2012 7:45pm |
Bearcat Member Since: 09 Dec 2011 Location: Dublin Posts: 57 |
Is that the DPF thing in the pic? The bane of many peoples lives...... Current...07 90 Puma commercial
Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
14th Feb 2012 3:37pm |
is the DPF installed on 2.4 TDCi Transit. The DPF on Defender is closed to the cat to permit the cleaning cycle at very low speed. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Feb 2012 5:29pm |
