Home > Wheels & Tyres > BF Goodrich KM2 tyres cracking
Page 3 of 4 <1234>
Dan A
konabikes11 wrote:
RED-DOT wrote:
Good quality truck tyres with 15-18mm drive pattern do this when nearly new due to the tread flexing when scrubbing but then they settle down. I think BFG have softened the compound now to comply with US noise regulations and i don't think you have a fault but just good tyres doing thier job which looks like hard cornering.
Thumbs Up Also IF* it's on the off side of the truck maybe round abouts not helping
Its the near side
Post #123516 12th Feb 2012 7:04pm
RED-DOT
There are more right hand corners than left in the UK!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #123517 12th Feb 2012 7:06pm
Its the near side[/quote]
Strange, wouldn't worry to much
Post #123518 12th Feb 2012 7:06pm
Surrey Rover
RED-DOT wrote:
Looks like heat degredation by tyres doing hard work.
I'd agree, looks like you have been spanking it around and the tyres have heated quickly. Nick
2.2 110 Tipper
Post #123531 12th Feb 2012 7:52pm
Lookers Park Royal
I've had mine on for 2 years and 9,000 miles with the majority of the mileage off tarmac. Just had a look at mine and there's no sign of cracking or degradation.
It could be (as mentioned) pressures (mine are 32F/35R) or as both tyres in question are on the same side then perhaps they've been subjected to a chemical whilst on the road that's reacted with the rubber?
Worth asking the supplier (or perhaps Andy AJS) can advise if BFG are aware of customer issues with the KM2's and if so is there a goodwill process in place?
James Thumbs Up
Post #123532 12th Feb 2012 7:54pm
landy andy
Looks normal to me, just been pushed hard on the road. Nothing to worry about.
Andy
Post #123533 12th Feb 2012 7:55pm
AndrewS
Either pushed hard or chemical damage 130's have feeling's as well you know Smile
Post #123572 13th Feb 2012 5:13am
Zagato
Any update on this?
Post #130818 12th Mar 2012 7:24pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Just went to check mine... BF Mud KM2
17000km and allready showing cracks on the back tyres! Shocked The ones I had on my 90, (the old BF Mud) only started to show these signs about 45000km of use ... Neutral Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #130820 12th Mar 2012 7:38pm
Could heat or consistent high speeds be anything to do with it?
Post #130821 12th Mar 2012 7:45pm
AndrewS
Doubt constant high speed, we cover lots of miles for hour after hour and have had no issues. 130's have feeling's as well you know Smile
Post #130858 12th Mar 2012 9:04pm
Cibit
Mine have 40k on and are wearing well but you have way more tread if you want to swap Very Happy
Hope you get it resolved though Thumbs Up
The pictures show some residual spray of some kind. Chemical or perhaps it is fine rain? 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #130899 12th Mar 2012 11:10pm
Bryden
South Africa 2008 Defender 110 Puma 2.4 SW Stornoway Grey
As a previous tyre developer and being a polymer chemist I can offer an informed opinion.
Although there are reasons why a tyre may chemically craze or crack the pictures supplied illustrate typical hard cornering damage which is especially prevalent on new tyres with a block tread pattern. it should diminish as further wear takes place.
Post #130918 13th Mar 2012 6:49am
sswalker
Australia
I am in a hot climate with around 50,000km on mine with no signs of cracking other than when I have not reduced air pressure over rocks.
Simon Simon
Post #348917 2nd Aug 2014 2:36am
AJS4X4
Any problem you think you have go see a tyre dealer for advice.
Looking at the photos I would look at tyre pressure and driving style.
My gut feeling as we can only see photos is "if" they were sent back for inspection the letter would read............ No fault found. Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #349126 3rd Aug 2014 6:26am
Page 3 of 4 <1234>
