![]() | Home > Wheels & Tyres > BF Goodrich KM2 tyres cracking |
Dan A Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 61 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Tyres are 265/75/16
Have mainly been used on road with only a few off road miles |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Personally I see no problem. They look just the same as mine
Have a look at my Gallery should be a pic on there of mine
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
What pressures are you running? What does the centre of the tread look like? It may be that your pressures are too low, so the tyre is running on the edges.
Dan A, looks like cracking to me ......they should not be looking like that if you have only had them a short while ?
looks like the compound of the rubber is braking up..... take them back and ask your supplier to investigate the problem with BFG ![]() |
35 front 40 rear. Its only 2 of the tyres that are cracking on the ns Brendan i only got them in november and done around 1600 miles. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Looks like heat degredation by tyres doing hard work. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
If I remember rightly the Defender owners manual say's 32 psi front and 38 psi rear. That's what mine are anyway
Do you use a hot water wash to clean the vehicle (very long shot though)
Good quality truck tyres with 15-18mm drive pattern do this when nearly new due to the tread flexing when scrubbing but then they settle down. I think BFG have softened the compound now to comply with US noise regulations and i don't think you have a fault but just good tyres doing thier job which looks like hard cornering. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Not washed the car since they were fitted ![]() |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Mine were like that although they were a lot older and had done a lot more miles. Strange it's only on one side of the vehicle though.
