Home > Puma (Tdci) > Question For Weekend-What Cause The Truck To Drift Left?
Fatpig
China 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Given Conditions:
I. New Truck 110SW
II. Replaced All Four Shocks
III. Replaced Steering Damper
IV. Replaced Steering Wheel
V. 30mm Wheel Spacer
Result: Defender sit with a noticed angle to the left when viewed from rear, and with a significant drift to the left. It was fine before the modifications. When the truck going 50 mph in 5 seconds it will surely end up on the hard shoulder, if steering wheel not kept at the one o'clock position.
Post #123353 12th Feb 2012 3:02am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Process of elimination:-
If vehicle now lists to the Left side then this means ?? suspension height has been altered. [ Lowered on Left or Increased on Right ].
Steering wheel - no effect on suspension height
Steering damper -no effect on suspension height
Wheel spacer -no effect on suspension height
Shock Absorbers - Rear can be changed without disturbing springs etc:
FRONT cannot be changed without partially dismantling suspension.
If the vehicle was alright before these changes then check the front suspension and check that the springs are correctly positioned - measure heights etc: Whistle Whistle Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #123354 12th Feb 2012 5:51am
22900013A
Sadly mine has drifted left from new, and its totally standard...
Post #123366 12th Feb 2012 8:33am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
But if you take it abroad i bet it drifts to the right Whistle , camber sensitive Thumbs Up
Post #123370 12th Feb 2012 8:59am
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Mine drifts to the left apart from when it drifts to the right !! Laughing
Post #123379 12th Feb 2012 10:13am
T1G UP
mines fine Thumbs Up they use to fit different length springs to td5s etc to allow for driver weight but they've stopped. Check your spring colours and see if there the same, may have put the wrong ones on?
Post #123382 12th Feb 2012 10:22am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
might be worth checking the top swivel bearing as well.
Also - do you have a binding front caliper? BM52
Post #123388 12th Feb 2012 10:39am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I had that problem on my 90 Td5 a few years ago...
I had replaced the original steering damper (as it was leaking) for a DeCarbon gas shock ... Terrible! Couldn't keep the car straight!
Removed it and replaced it for an oem one and all was fine ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #123404 12th Feb 2012 12:04pm
WelshGas
According to the poster = everything was OK before the modifications, and the vehicle is now leaning to the Left when stationary and viewed from behind. So I would presume changing the Shocks - probably one of the front ones has upset the geometry as you would have to partially dismantle the front suspension to do this. Bow down LANDYWATCH
Post #123405 12th Feb 2012 12:06pm
Fatpig
Road camber...that's classic, but I think you can tell if it's road camber or something internal once you drive it.
I do agree by the process of elimination, the cause for the truck leaning to the left must be either hi/right or lo/left suspension. And yes rear shocks are exchanged without removing the springs. So most likely one of the front front spring must be set wrong.
Here is my next question, What can you possibly do wrong putting on one of the front spring while exchange shock damper to have the offset, yet the truck still can be driven for the past 500 miles only with a significant annoying left drift?
Post #123423 12th Feb 2012 2:29pm
richuk
Flat tyre Whistle Rich
semper in excretia sumus solim profundum variat
Post #123424 12th Feb 2012 2:41pm
Could one of the springs not be seated properly, particularly on the rear? Or if the front springs are handed, have they perhaps been mixed up and fitted on the wrong sides? Darren
Post #123425 12th Feb 2012 3:03pm
Fatpig
Again the rear shock was replaced while the springs attached, and front shocks were replaced one at a time. So, couldn't been mixed up.
One of the front spring not seated correct is a possible cause, have any one on here have replaced shock themselves know how a front spring could have seated wrong?
Post #123563 12th Feb 2012 10:56pm
WelshGas
One other thought - Was a coil spring compressor used on the front springs???? Question Question and a very stupid question, but you never know - was it removed?? Bow down Bow down LANDYWATCH
Post #123564 12th Feb 2012 11:06pm
Fatpig
Do you mean was the spring even put back after removal? If that's the case, yes the spring in back in there. As of spring compresser, being mechanical challenged I don't know what it is?
Post #123569 13th Feb 2012 2:27am
