Home > Maintenance & Modifications > Spring removal |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
On my Puma i removed the rear spings without a compressor but needed one for the fronts. they are very cheap now and save a load of hassle
http://www.screwfix.com/p/coil-spring-comp...fAodejOhgg BM52 |
7th Feb 2012 10:41pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
I did mine without a spring compressor without any drama .... front and rear
Just watch the flexi brake pipes.. Guns and Landrovers .... anything else is irrelevant. |
8th Feb 2012 7:40pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Did you need to jack the chassis up so that you could lower the axle far enough or not? 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
8th Feb 2012 7:46pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5740 |
No need for spring compressor.
Just need to jack chassis as high as you can, take wheels off, so axle can drop lower, and you may have to remove anti roll bar clamps if fitted. Andy |
8th Feb 2012 8:12pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8092 |
i have never used a spring comp on a LR. as above jack the chassis up then drop an axle as far as it will go watching brake pipes etc, may need to remove a shock on the rear to do it. front shocks obviously need to come out to get the spring out. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Feb 2012 8:38pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Never needed one. You can also lift the front with a hoist, does the same thing. Whilst you're at it, put open turrets in, makes the job easy the next time you do it.
8th Feb 2012 8:49pm |
