Home > Puma (Tdci) > 1:1 replacement for seat heating switch with multi level ?
1ten.neuss
Germany 2008 Defender 110 Puma 2.4 SW Keswick Green
Does anybody knows a 1:1 switch replacement for the standard heat seating switch ?
I like to replace the original one by a multi level switch for greater comfort. It should fit in the original dashboard position and shouldn't destroy the Defender look'n'feel too much.
Thanks,
Bernd
Post #121220 4th Feb 2012 2:28pm
T1G UP
that would be a nice option......let us know what you find.
Post #121238 4th Feb 2012 4:00pm
dgardel
Italy
but you need a complete different harness, not only the switch.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #121268 4th Feb 2012 6:26pm
ericvv
Seems nice idea,but not sure it makes sense in case of a Defender. The standard system (on or off) has a thermostatic setting of the heating elements in the seats which turn the heating off once the seat temp reaches approximately 37°C, or normal body temp.
By adding a multilevel switch alone, that thermostatic control will not change, still will switch off at the set max temp. As that max temp setting means the seats are not heating to a very high temp (at least my seats never get super warm when I turn it on, what would a multilevel switch really do?
Other systems, like VW, have indeed a 5 level switch, but levels 3 and up allow the temp to climb to higher °C than in our case.
So don't see the interest, unless we would be able to change the max thermostatic turn off point, but that will get very complicated. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #121273 4th Feb 2012 6:58pm
FG
Sweden 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
To be able to change the max thermostatic turn off point would be nice. In my opinion the heated seats don't get warm enough.
/FG
Post #121296 4th Feb 2012 7:43pm
Gareth
I bypassed the thermostat in my drivers seat because it was not working at all. I pulled the back rest cover off, removed the seat heater pad and soldered a wire bridge over the contacts. It gets really nice and warm now, and does not overheat at all. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #121310 4th Feb 2012 8:25pm
dgardel
Italy
You can install a "trigger" like this one.
You can control the temperature by "varying" the on-off duty cycle frequency.....
Max temp: always ON (12V)
Reduced Temp: ON - OFF - ON - OFF - .......
More long is the OFF period less °C (or °F) you have.......
Using this one
You can install it on the facia or on the cubby box or on the seat or ......
I suppose that the heaters (back and rest) on the original LR seats are electrically connected in "series".
If you install the trigger you can connect the heaters electrically in "parallel". In this way you can have more max warm. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #121397 5th Feb 2012 12:10am
PaulMc
Re: 1:1 replacement for seat heating switch with multi level
Thanks,
Bernd
I don't know of any switch that would directly replace the heated seat switches and perform the function you describe.
However, I have thought of a couple of options that might work -
1. If you don't have headlamp levelling fitted, you could use a modified headlamp levelling switch as a temperature control for both seat heaters -
A knob with a plain line instead of the headlamp symbol is available, Part No. YUM10001 (Rover) & YUM10001L (Land Rover) -
I believe that the Defender headlamp levelling switch has resistors built in, these would probably not be suitable to use with the load of the seat heaters.
The Rover 100/Metro used a heater fan speed selector switch of the same dimensions as the headlamp levelling switch, which had no resistors built in and used an external resistor with multiple taps to control the speed of the fan, but it has a Fan symbol on its scale.
Part No. YUK10003 (EEP0106) - £6.95 on eBay -
http://www.ebay.co.uk/itm/METRO-HEATER-FAN...0534471630
I've previously posted details of this switch -
here - http://www.lro.com/forum3/viewtopic.php?p=474790#p474790
and here - http://www.d-90.com/forum/showthread.php?p=298971
2. Another option would be to modify the heated seat switches to be non-latching switches.
This can be done by either swapping the switch cap onto a live-switching non latching switch body, or you can remove the latching pin from the switch's mechanism.
With this done, you would use the non-latching switch to increment the output of something like this -
http://www.quasarelectronics.com/cr0025-dc...30v-8a.htm
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #121403 5th Feb 2012 1:29am
dgardel
Italy
But you need a resistor pack for obtain the 3 level of warm...
Normally the resistor pack is cooled by the fan air stream.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #121415 5th Feb 2012 8:52am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
A MOSFET transistor and simple 555 timer IC used as a Pulse Width controllor would allow the temperature to be set at anything between off and maximum Wink.
BTW: if both heaters (seat and back) are normally wired in series I would never wire them in parallel as they will be seriously overloaded !
It would be interesting to know why some people report the heated seats to function very good while others find them to help very little ? Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #121494 5th Feb 2012 1:59pm
dgardel
Italy
Using this one
Here a simple PWM regulator
IID Pro MV License
Post #121549 5th Feb 2012 5:52pm
Daniele you are a legend Thumbs Up
Post #121551 5th Feb 2012 5:56pm
dgardel
Italy
Or buy it on the bay for £10,00 more to less...
http://www.ebay.it/itm/DC-12V-24V-3A-Motor...214wt_1141
http://www.ebay.it/itm/12V-24V-36V-10A-DC-...5034wt_907 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #121559 5th Feb 2012 6:04pm
dgardel
Italy
IID Pro MV License
Post #121568 5th Feb 2012 6:18pm
