![]() | Home > Technical > small leak |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Google Defender Water Ingress Manual...sealant into window rubbers, take off false window hinge and treat with sealant, roof to windscreen frame etc, gutter, sunroof, cappings, etc etc
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 ![]() ![]() ![]() |
Thanks for that will order some sealant asap, should i run some over the foam joint under the windscreen gutter?
That would be tricky. I sprayed mine with ACF-50 and then put a more enduring layer of Wurth Rust Protection Wax which provides a tough stickeable film over the foam to hopefully repel any water. Both are aerosols and there will be other products suitable i am sure. The Wurth stuff is good as it is clear and quite tough
![]() This was my solution also for the foam strips between the rear top and cappings on the rear tub! It doesn't show you have done it ![]() |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Zag - Is your Wurth product what they call 'Wurth corrosion protection spray'?
Pete |
That's the stuff Pete. Dunsfold DLR put me onto it
on Bob's advice, I order one of the last 1kg tins of dum-dum in the country...
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
i had the same problem turned out to be my gasket behind the windowscreen hinge
I left two messages and ordered online as well just after Bobs post but didn't hear anything! I have a new tin somewhere just can't find it ![]() Put yours up on E Bay Steve ![]() ![]() |
it's not arrived yet, but fingers crossed
He's been flooded with orders I expect, if you don't own a Rover then it's a no no....
Apart from the confirmation email there is no further contact.
Mine turned up three days after ordering on PJS ? couriers. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Yep just had a email from JRW saying they only sell to those who are buying a screen from them. Will Defender 90 XS TD5 (03 Reg) |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
now that's given me an idea. Here was I waiting for a couple of dry days so I can seal those gaps front and rear (where the foam strip is) with black mastic as rain is wicking through them into the footwell but I have an aerosol of Fabsil (used for waterproofing caravan awning roofs) in the shed so I might soak them in that instead to see if it works Thanks Zag ! ![]() |
Try this lot - about half way down the page.
I couldn't get the checkout to work when I tried at the weekend. http://www.repairproducts.co.uk/page4.htm Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
