- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
AlpsLandy
Cheers Boxer . Just to clarify - the wet foam on mine was that strip/join which can be seen from outside just below the gutter which is below the windscreen. That has also been sealed all along the outside and I think it was the main culprit. Hope Yours stays dry now and mine too... 2011 Defender 90 SW
2006 Discovery 3 HSE
4th Feb 2012 1:11pm |
