Home > Puma (Tdci) > Lost the will to live..........
Page 2 of 2 <12
mse
chay wrote:
Mike,
Thanks for the suggestion, however the dealer that I brought the Puma from is on the other side of the country, 300 miles away, we moved about 5 months after the purchase.
When we did move, I contacted LR Customer Services and they stated that any warrenty work would be carried out by any dealer, anywhere. However, most dealers are not really bothered about Defender purchasers, they are only interested in Diso and RR buyers.
And the bottom line is "Well Land Rover warrenty say............."
An invidious situation.
Regards
Chay
Warranty work is done anywhere - and should be accepted by any other dealer; however, the liability as with anything is always with those that did it...so unless your dealer is part of a chain; the issue is there Mike
Post #11930 13th Jun 2009 4:49pm
Shropshire Lad
Chay
See my previous posts. You have my sympathy! I sold mine I was so fed up with it! A woefully manufactured product (as all bar the Disco 3 are in my experience). Picking up a Nissan Pathfinder for under £18k brand new to use as a work horse, bit different but it can't be any worse.... LR 90 XS GONE! Hurrah!
Post #12006 15th Jun 2009 1:10pm
mse
if your lucky it will stay together, work and someone will give you 50p for it in 3 years when it gets expensive Laughing Mike
Post #12010 15th Jun 2009 4:42pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Shropshire Lad wrote:
Chay
Shopshire Lad
Be sure not to load your nissan any where near the recommended laden weight weight constantly and use as a work truck because if you are like the largest roading company here in New Zealand that has over 40 of them and then get suspension problems, gearbox problems etc nissan will walk away from your warranty (within a year)as you are "overloading" them. also they got the same thing with toyota Hi Lux running for cover, but amazingly not FORD!
Post #12023 15th Jun 2009 6:58pm
Shropshire Lad
Mike
Is that "stay together" as in like a Landy.... ala Triggers Broom!!!! Rolling with laughter LR 90 XS GONE! Hurrah!
Post #12130 19th Jun 2009 11:43am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Chay - sounds like you've had a bad time of it.
Not all dealers are as bad. I took mine into Stratstone Milton Keynes to get some work done and they've been really great so far. I told them the rear step was corroding so they just put a new one straight on. The paint on the intercooler rad is going to get re-sprayed (although it'll take them 10 days apparently Shocked ).
I hope your experiences improve. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #12176 20th Jun 2009 5:59pm
Page 2 of 2 <12
