Home > Puma (Tdci) > Lost the will to live.......... |
Shropshire Lad Member Since: 03 Nov 2008 Location: Shropshire Posts: 40 |
Chay
See my previous posts. You have my sympathy! I sold mine I was so fed up with it! A woefully manufactured product (as all bar the Disco 3 are in my experience). Picking up a Nissan Pathfinder for under £18k brand new to use as a work horse, bit different but it can't be any worse.... LR 90 XS GONE! Hurrah! |
15th Jun 2009 1:10pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
if your lucky it will stay together, work and someone will give you 50p for it in 3 years when it gets expensive Mike
15th Jun 2009 4:42pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
Shopshire Lad Be sure not to load your nissan any where near the recommended laden weight weight constantly and use as a work truck because if you are like the largest roading company here in New Zealand that has over 40 of them and then get suspension problems, gearbox problems etc nissan will walk away from your warranty (within a year)as you are "overloading" them. also they got the same thing with toyota Hi Lux running for cover, but amazingly not FORD! |
15th Jun 2009 6:58pm |
Mike
Is that "stay together" as in like a Landy.... ala Triggers Broom!!!! LR 90 XS GONE! Hurrah! |
19th Jun 2009 11:43am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Chay - sounds like you've had a bad time of it.
Not all dealers are as bad. I took mine into Stratstone Milton Keynes to get some work done and they've been really great so far. I told them the rear step was corroding so they just put a new one straight on. The paint on the intercooler rad is going to get re-sprayed (although it'll take them 10 days apparently ). I hope your experiences improve. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
20th Jun 2009 5:59pm |
