Home > Puma (Tdci) > Driver's door
bustduster
Driver's door
Just back from its first scheduled service. One of the items down for attention was a poorly fitting drivers door. Basically it appears to be protruding around 5mm from the body line at the curve, just above the door handle, with less of a protrusion at the top and bottom. This results in some wind noise that does not occur on the other doors. Dealer said he adjusted it but there is no improvement. Is there any adjustment that can be made either to the hinges or door catch (or both) that would result in a better alignment?
Post #11961 14th Jun 2009 12:56pm
Grockle
They need to adjust the stricker more,ours was the same now fixed. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #11962 14th Jun 2009 1:00pm
bustduster
Thanks for that Grockle; will drop it back in next time I'm passing the dealer's.
Post #11970 14th Jun 2009 5:19pm
