Home > Technical > Anti Roll Bars and Alloy Wheels
taffyscouser
Just had a defender described by a dealer as having a "Style Pack on it" Fair enough so had a look under it and no front or rear anti roll bars but LR brochure states that these are part of the pack. Anyone know if this is a change to specs on brand new 2.2 models or dealer pulling fast one and adding alloys, and tow bar to a metallic finish vehicle and claiming it is style packed.
Post #119531 29th Jan 2012 3:36pm
Knot Yet
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
Should have the following as part of the Style pack (as of August 2011):
Boost Alloy Wheel & Continental ContiCrossContact AT Tyre
Front & rear antiroll bar
Locking Wheel Nuts
Metallic Paint
Tow Ball, Drop Plate and Electrics
Hope that helps
Jean Defender 110 Puma Utility XS
Post #119552 29th Jan 2012 5:01pm
taffyscouser
Must be a bitsa then? There are definitely none on the front or back of the vehicle. All the other stuff is in place. Are they really required with the alloys? Would make a great bargaining tool if they should be there and are missing. Insurance problems to a new owner?
Post #119555 29th Jan 2012 5:11pm
Knot Yet
Personally Ive found they make the ride much more comfortable as less rolling around corners.
If its sold with a Style pack they should be there - the alternative is to request the print off that states exactly what was included when it left the factory - this will identify if it should have had the roll bars fitted
Not sure re the insurance but principal dictates if sold with Style pack they should be there Very Happy Defender 110 Puma Utility XS
Post #119558 29th Jan 2012 5:18pm
taffyscouser
Thank you so much for the help and I will be double checking with dealer tomorrow re the exact spec on it. As you say, if it IS a style pack they should be on there. If they have cobbled some extras to make it almost equivalent to a style pack then ok Embarassed if not a little naughty for some unsuspecting buyer that has not read the LR brochure closely enough.
Post #119563 29th Jan 2012 5:33pm
Knot Yet
Exactly my sentiments - good luck and keep us updated Thumbs Up Defender 110 Puma Utility XS
Post #119565 29th Jan 2012 5:38pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
2007 I know but county with alloys should have had anti roll bars fitted, then as now it came with the alloys, not done at the factory Confused
I was just happy it was the correct colour and lenth Laughing
Post #119959 30th Jan 2012 10:17pm
I had an 03XS came supplied from the factory without A/R bars .. soon fitted front and rear, improved road manners
Post #120001 31st Jan 2012 7:26am
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Anti roll bars
Hi
At the risk of sounding less than experienced what does an anti roll bar at the front and back look like!
ive got a 2011 my xs dc and would like to know what i should have!
Deano
Post #120128 31st Jan 2012 5:41pm
Re: Anti roll bars
Dean Watson wrote:
Hi
Deano
it's a U shaped bar that is fixed to both sides of the chassis and also on each end of the axle, about 20mm thick. it limits the axle movement, hense is makes for a firmer ride but less articulation off road. so good and bad depending on how you use the truck
Post #120141 31st Jan 2012 5:59pm
taffyscouser
If I get an even better price I may haggle them down even further and fit a set myself. Are these readily available second hand? or should I insist dealer fits them from new?
Post #120249 31st Jan 2012 11:43pm
Knot Yet
I vaguely remember something in LRO about fitting yourself so guessing possible, my understanding is unless you wish to do hard core off roading and need greater articulation, it's better to have them. Also not sure where you would stand if they came fitted and then removed, if the vehicle was then rolled in an accident I wonder how the insurance would stand?
Probably a good idea to ensure they haven't been removed in the first place Thumbs Up Defender 110 Puma Utility XS
Post #120254 1st Feb 2012 4:34am
